front blowhole on ahanix platinum xp?
Postby MicrowavedWater » Mon May 12, 2003 10:23 pm
do you think it would look good...
I need to improve airflow somehow..
any suggestions?
Soyo KT333 Dragon Ultra Platinum, AMD athlon XP 2100+, Geforce3 Ti500, Western Digital 40GB 7200 RPM, Lite-on 16x DVD, Lite-on 40x12x48 CD-RW, *NEW* 400 watt power supply, AND a ahanix Platinum Xp case... :)
MicrowavedWater
Postby Tulatin » Tue May 13, 2003 3:38 pm
To do this, you'll need aeither a dremel, or a 3" holesaw. Basically, just remove the front panel (by the 6 screws AND clips...), then remove the little temp.display LCD and button cluster - you'll have to mod a 5.25 inch bay to accomodate these later - then you pretty just measure out the loacation ,adn drill away. In canada, a holesaw for metal is $21 about $12 american - and the holesaw for wood/plastic is around $5 canadian.
Finally, when using holesaw, have a firm grip of the drill - it can get away surprisingly easily.
Tulatin
Postby MicrowavedWater » Tue May 13, 2003 7:20 pm
sounds good...the only thing is that there is a indentattion line down the middle...
i wasnt sure how it sould look with the duct and fan.
Also, on one site it says you can cut off the top of a funnel fo a duct.
Does this work?
MicrowavedWater
Postby Tulatin » Tue May 13, 2003 8:51 pm
It should - and if yu really dont want the line to be cut off by the blowhole, just fill this little ditch up with automotive putty (for fixing dents) and paint it like the rest of the case. The blowhole would look okay if it's a black fan, or really cool if it's an LED fan.
Tulatin
Postby MicrowavedWater » Wed May 14, 2003 7:52 pm
I was thinking of using one by thermal take that was blue and turned red to show HD access...
MicrowavedWater
Postby Tulatin » Thu May 15, 2003 3:55 pm
You mean the blue-eyed fan? Or one like the Coolmod on the V9. That would wokr fairly well, and it would look coll when you hear your hd spinning, and your fan glows red...
Tulatin
Postby MicrowavedWater » Thu May 15, 2003 7:17 pm
I was thinking about the blue eye one...
MicrowavedWater
Postby Tulatin » Fri May 16, 2003 9:03 am
So What are you waiting for? Mod, cut and fan away! (Post pics after if you can)
Tulatin
Postby MicrowavedWater » Mon May 19, 2003 5:28 pm
prob have to wait till school is out....
planing though so when it comes time I'll know what I want to do.
Life is really stressful right now--
between upcoming exams, crazy teachers, and too much school work/projects
MicrowavedWater
Postby Tulatin » Mon May 19, 2003 6:02 pm
Welcome to the Club. Albiet I've got an easy semester (Buisness, English, History (Best Part of My Day [The Class sucks, but she's there]), Lunch and Drama. I only have to Study for 2 Subjects! :twisted: Best of luck on the Exams.
Tulatin
Return to System Modification
