It is currently Tue Sep 18, 2018 10:00 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Thu Jun 27, 2002 4:19 pm
Post Pics of your Case Mod and/or PC Insides
PostPosted: Thu Jun 27, 2002 5:52 pm
Hey your avatar is a bit big there hombre. I'm on a 56k modem right now and it was hell waiting for it. Keep it around 6k, okay senor? :x
Currently I don't have my case all hooked up, I'm on somebody elses comp. But, it is an all-aluminum SkyHawk case with 4 added fan placements for ventilation that I drilled in. Two are 120mm fans and two are 90mm fans, making the intake 200CFM. Along with a Volcano 7 and a slot fan :)
Goddam mad dog!
PostPosted: Thu Jun 27, 2002 8:38 pm
look at my spiffy avatar only 5k and well within the boundaries of the pixel limitations [80x80] my case however only has nifty stickers
PostPosted: Sat Jun 29, 2002 12:45 am
Working on a dual power supply mod to an old 386 server size case. I'm going to run Linux on a collection of old SCSI drives I picked up for cheap and I need the space for the drives and I needed the second power supply to plug everything in. I'll post before and after pictures when I am done.
PostPosted: Sat Jun 29, 2002 1:49 am
I don't think you'd call it a "mod" but my Tandy's missing a shift key so I attatched a small piece of plastic to it. Oh, and my li'l sis wrote "Amy Sucks" (that's the name they call me in real life) on Gollem a little while ago. I haven't bothered to remove it yet, so if any of you /really/ wan to see these, I'll be sure to snap some pics when I get the digital camera back.
But, as for a real mod, I am going to replace an LED on my system when I get the guts to. The hdd light is a very ugly orange and I'm going to replace it with a blue or red LED. One of those super-bright ones they sell at radioshack.
PostPosted: Sat Jun 29, 2002 1:59 pm
On the case im putting together, im thinking of airbrushing the one side, then putting an etched window on the door with blue or green LED's inside. A case badge might also find itself on the outside.
PostPosted: Tue Jan 28, 2003 9:43 pm
here is my 1st mod. check it out.
http://www.finitesite.com/logan/index.html
XP3200+
ASUS A7N8X-E Deluxe
1GB PC3200
3 X WD 80GB SE
FX5600 256MB
SONY DRU-540A
SONY DDU-1621
ASUS 52X CDRW
XP PRO
PostPosted: Wed Jan 29, 2003 10:21 pm
EDIT: Sorry I posted the wrong thing. Check out my case pics on my website. I took 'em with a crappy digital camera so they kinda suck. However, I took some newe pics. (updated as well), and they will hopefully be up in about a week. Thanks.
-Starbuck
Visit my Homepage and Ben 10 Games here
Hey I'm a GEEK and I'm proud of it!
PostPosted: Fri Jan 31, 2003 11:22 am
First of all, hey everyone. I'm a regular at the o/c forums, newbie here . . actually I didnt even know mobo.org had a forum till this morning.
Anywho there is the link to my case mod I did over the summer, please forgive the fuzzy image quality ::
http://www.geocities.com/knif_00/images/CaseModLit.jpg
Cutting that out was a bear by hand, no dremel or anything fancy. I used an 1/8th inch metal nibbler. Backed with an 8 by 8 inch square of transparent green Plexi I ordered from a Woodshop in Tennesee of all places. The lighting is thanks to an 8 inch Industrial White Cathode from ]www.sidewindercomputers.com They have excellent cathode kits for a good price. Hope you enjoy :)
::knif_00::
PostPosted: Sun Feb 09, 2003 5:30 pm
LOGAN-MR, cool looking computer.
