Am i on the right track ??
Postby windman » Mon Apr 21, 2003 3:59 pm
ok i've just started into the idea of modding my case
basicly all Ive done is change then side pannel of my pc60 case to a pc65 version and added a case light.
can you tell me if this is looking ok for a start point
you might also be able to notice that the cables have been changed and the wireing have been cleened up abit
thanks for any advice :):)
The whole world is a game and we are but players within it
but what a game :D
windman
Postby effika » Mon Apr 21, 2003 4:57 pm
Can you give us the links so we can see them? Tripod doesn't allow hotlinking and we can't see the pictures.
You should fold.
effika
Postby windman » Mon Apr 21, 2003 6:18 pm
but what a game :D
windman
Postby son0rous » Mon Apr 21, 2003 8:40 pm
links dont work either. reminds me of the post i put called "Stupid Tripod!!!". try putting the pics in a yahoo briefcase
son0rous
Postby Tulatin » Mon Apr 21, 2003 8:44 pm
try using angelfire too - or if you want, e-mail the pics and I'll put em up - REMOVETHISLIVEFIRSTmemex_r@hotmail.com
(A little anti-spam measure)
Tulatin
Postby effika » Tue Apr 22, 2003 1:47 am
Just cut and paste the links and they'll work. A little extra effort, but got to burn those calories somehow. :)
I really like what you've done so far. Have you considered chroming the drive face plates somehow? It would look really swank with some silver or a coordinating metallic color to match.
You should fold.
effika
Postby White Raven » Tue Apr 22, 2003 2:26 am
Right click on where the images are supposed to be and click properties and copy/paste the address into your address bar.
Looks good for a start. Keep it up.
-White Raven
White Raven
Postby windman » Tue Apr 22, 2003 11:46 am
my next stage plan is to look into the frount drove plates
also maby some new led fans to replace the old case fans
but as to what color not sure yet
but thanks for the input :)
but what a game :D
windman
Postby JoeCamaro » Fri Apr 25, 2003 3:06 am
for the drives check out right here:
http://www.pcmods.com/list.asp?CtgID=70
I'd look at the cooler master drive covers personally, even though they don't allow access to the audio inputs on the CD-roms, do you really need them anyway? A drill can easily fix any problem with the lights. The big thing about them are though that they include a matching button and the others don't. The copy and paste thing worked fine for me to see them and it looks pretty good. How did you organize the power cables?
1800+Mhz AMD Athlon XP, Asus A7N8X Deluxe, Nvidia Geforce4 4800Ti, 60gig 7200RPM ATA133 HDD, 1.0 gig 400mhz DDR RAM, Volcano 11 CPU Fan, Skyhawk 4350 Alum. Case/Side window+Blue Cathode Tube
1988 Camaro Conv. with 5.0 Fuel Injected V8
JoeCamaro
Return to System Modification
