BIG PROBLEM! BIG CRACK!!!!
Postby son0rous » Wed Apr 16, 2003 9:50 pm
my viewing window cracked when installing the switch for my cold cathode. I need good help fast. anybody have any solutions on how to fix it or at least conceal it so it cant be seen!!!! any feedback is welcome!
son0rous
Postby ssamurai26 » Thu Apr 17, 2003 12:29 am
If you are 100% sure that it's acrylic, then it might be possible to use an acrylic "weld", which is what's used to join acrylic seams. Other than that, you could probably just buy a sheet of acrylic and cut it to fit.
Abit KN9 Ultra
AMD X2 3800
Corsair DDR2 2X2GB
HIS Radeon 4670 1GB
Intel SSD
150GB Raptor
1TB WD Green X3
ssamurai26
Postby son0rous » Thu Apr 17, 2003 3:37 pm
cant tell if it is plastic or acrylic. probably gonna end up getting it replaced
son0rous
Postby Tulatin » Thu Apr 17, 2003 5:50 pm
yeah - your best bet would be to swap out the window - just get a chunk of plexi to fix it..
Tulatin
Postby son0rous » Thu Apr 17, 2003 5:58 pm
do most hardware stores have plexi or plastic the size that i need?
son0rous
Postby Tulatin » Thu Apr 17, 2003 8:38 pm
they should - thy home hardware - they have the most. And as to the size you need, measure first, then have them cut it.
Tulatin
Postby ssamurai26 » Thu Apr 17, 2003 8:41 pm
It's usually not difficult to find a decent replacement for clear plastics. Any decent hardware store/home supply center should carry it. You didn't list location, but assuming North America, you should be fine. I like acrylic over others, but for this application it doesn't really matter too much I guess. Also, if you bring a template, a lot of places will cut it for you if you don't have the tools.
Damn you and my slow typing Tulatin!
Abit KN9 Ultra
AMD X2 3800
Corsair DDR2 2X2GB
HIS Radeon 4670 1GB
Intel SSD
150GB Raptor
1TB WD Green X3
ssamurai26
Postby Tulatin » Fri Apr 18, 2003 6:38 pm
Damn Yourself Man!
Tulatin
Postby JoeCamaro » Mon Apr 21, 2003 2:02 am
I know that OSH is usually friendly enough to cut things like that for customs and that they carry plexiglass. It's a little expensive for plexi there. Home depot carries much cheaper things like some acrylics and that they SHOULD be able to cut a square for you but don't expect to get it done.
1800+Mhz AMD Athlon XP, Asus A7N8X Deluxe, Nvidia Geforce4 4800Ti, 60gig 7200RPM ATA133 HDD, 1.0 gig 400mhz DDR RAM, Volcano 11 CPU Fan, Skyhawk 4350 Alum. Case/Side window+Blue Cathode Tube
1988 Camaro Conv. with 5.0 Fuel Injected V8
JoeCamaro
Postby son0rous » Mon Apr 21, 2003 11:03 am
OSH :?: :?: :?:
son0rous
Return to System Modification
