How to install fans in the Aopen H700 full Tower
Postby Mighty Mike » Wed Mar 19, 2003 3:47 pm
Hi guys & galls
I bought this case, but I am not sure how I should let the airflow go.
I got 4 80 mm installed and a turbo 5,25 drive in front that blows air out.
Check this jpg out and let me know ;)
http://www.aopen.com/products/housing/e ... h700_0.jpg
Many Thanx
Mike
[ to boldly go where no one has gone before.. ]
Mighty Mike
Postby MicrowavedWater » Wed Mar 19, 2003 9:56 pm
THis is how i think it goes.
Hot air rises, so put intake fans at bottom in front, and outtakes in the upper rear.
I am not sure about the bottom rear space though.
Micro
Soyo KT333 Dragon Ultra Platinum, AMD athlon XP 2100+, Geforce3 Ti500, Western Digital 40GB 7200 RPM, Lite-on 16x DVD, Lite-on 40x12x48 CD-RW, *NEW* 400 watt power supply, AND a ahanix Platinum Xp case... :)
MicrowavedWater
Air Flow Direction
Postby Mighty Mike » Fri Mar 21, 2003 6:28 am
Hey,
thanx but offcourse I knew that, it is just that this case has a lot of room for fans even on the side. Don't know what to do with them???
Skoll
Mighty Mike
Re: Air Flow Direction
Postby Toby B. » Fri Mar 21, 2003 6:43 am
Mighty Mike wrote:Hey,
Skoll
In this instance when trying to determine the position of case fans mounted on the side of the case becarefull not to disturb the airflow to the heatsink fan. IF you mount a case fan directly across from the heatsink then face the case fan to blow in. IF you have a place to mount a case fan on the top of the case then direct that fan to blow out (up).
Toby
Toby B.
Return to System Modification
