WINDOW QUESTION
WINDOW QUESTION
Postby patriotguitarist » Mon Mar 10, 2003 1:26 pm
This my be a very dumb question but is it possible to buy just a side pannel with a window to replace the one I have or would it be better to just buy a whole new case. I dont feel right about cutting away at one.
Trample The Weak, Hurdle The Dead.
patriotguitarist
Postby dharbert » Mon Mar 10, 2003 5:07 pm
Yes, you can buy a pre-made side panel with a window. It just depends. What case do you have?
Alternately, you could send your side panel to these guys http://www.directron.com and they will put a window in it for you.
dharbert
Return to System Modification
