Mini-ITX ????
Mini-ITX ????
Postby MicrowavedWater » Sat Mar 08, 2003 11:28 pm
I'm kinda confused abou tthis form factor.
How powerful are the processors???
Can they handle games? which ones?(starcraft? UT2k3?)
any info would be helpful.
thanks
Micro
Soyo KT333 Dragon Ultra Platinum, AMD athlon XP 2100+, Geforce3 Ti500, Western Digital 40GB 7200 RPM, Lite-on 16x DVD, Lite-on 40x12x48 CD-RW, *NEW* 400 watt power supply, AND a ahanix Platinum Xp case... :)
MicrowavedWater
Postby Valour » Sun Mar 09, 2003 1:43 am
I think you mean ITX; the only ITX boards I know of are made by VIA for VIA processors (used to be Cyrix). Most people use them for appliance-type devices like to record TV programs or something like that. The CPUs are not very powerful and the motherboards don't have AGP slots, so no they won't play games.
You might try a flex-ATX board if you're looking for something small and powerful. Shuttle puts them in their XPCs, and Aopen and Iwill make them too.
-Jem
Valour
Return to System Modification
