Enough Power for this Mod??
Postby USMC Rigger » Sat Feb 15, 2003 12:22 pm
Hey all I have recently moded my case to include a side window and a blow hole for a 120mm fan. I am aready running 4 80mm case fans and I also installed a blue cold cathode light. I am not sure if the 400w power supply is enough for all of it. Here are my computer specs:
Athlon 1900+
MSI K7N2-L NFORCE 2 MOTHERBOARD
CHAINTECH GEFORCE 4 TI 4600
HERCULES GAME THEATER SOUND CARD
WINDOWS XP HOME EDITION
Any advice would be greatly appreciated.
8)
USMC Rigger
Postby joeyscales » Sun Feb 16, 2003 5:44 pm
You should be o.k. with that PSU. Check your voltages to ensure everything is were it should be.
joeyscales
Postby CometbeatsAjax » Mon Feb 24, 2003 1:33 am
Why so many fans??????
Intel 865 PERL
Intel P4 2.8c (800 FSB)
Kingston DDR 400 256x2 in Dual Channel Mode
MSI Ge-Force 4 Ti4200
Maxtor 60 GB DiamondMax Plus 9
Plextor 48/24/48A
Antec SX 835(2)
Klipsch 4.1
Sony 19" G400
Cable@6000kbps
CometbeatsAjax
Postby joeyscales » Mon Feb 24, 2003 8:15 pm
Actually the amount of fans he is using isn't over the top. I am running 7 case fans, not including my video card or cpu cooler. The more the better. Helps keep all the computer components cooler.
joeyscales
Return to System Modification
