a custom painted antec soho i did
Postby dirtedug » Sun Feb 16, 2003 5:48 pm
from stripping the case down cutting the hole then painting ,reassemble maybe 2 hours total
dirtedug
Postby dirtedug » Sun Feb 16, 2003 8:07 pm
i posted an answer don't know where it is though but it took about 2 hours from the time i pulled it outta the box till i was admiring it done :D
dirtedug
Postby len444 » Mon Feb 17, 2003 2:38 am
joeyscales wrote:About how long does it take for you to do this? From start to finish.
and might i add- what are you doing for initial surface prep, as some of it is plastic (sand surface, and wipe down w/ some kind of solvent?)? i'm sure that a custom auto finish quality paint job takes some time to do (prep is 90+% of the job)!
len444
Postby dirtedug » Mon Feb 17, 2003 8:04 am
the metal pieces get sanded with 800 grit paper carefully as not to break through the original finish the plastic pieces get abraded with a synthentic "scotch brite" pad then sprayed with a special plastic adhesion promotor then its right into paint :wink:
dirtedug
Postby len444 » Mon Feb 17, 2003 2:50 pm
thanks for the info!
len444
Postby White Raven » Sun Feb 23, 2003 9:46 pm
This looks really nice. I have a friend that does automotive paint and restoration and I have the exact case and was thinking of having him paint it. This is an incentive. Great job!
-White Raven
White Raven
Previous
Return to System Modification
Users browsing this forum: Lindex [Bot] and 1 guest
