It is currently Tue Sep 25, 2018 11:35 am
PostPosted: Mon Jan 13, 2003 4:29 pm
What are the opinions on this case?
PostPosted: Mon Jan 27, 2003 12:01 am
looks like it has pretty good cooling, but if ur looking for a mod case i would look for something a little more pleasing to the eye. but if u just want a regular case it isn't a bad choice.
PostPosted: Wed Feb 12, 2003 9:47 am
Best case I've used.
Best thing about it (apart from looks) I think is it's capacity - I emptied a full tower's worth of kit into this thing, which is almost half the height. Ventialtion is good, better if you put some higher cfm fans in. The removable m/b panel is a godsend for stripping down, and all drives bar the CDROM's are mounted in racks, again making access a piece of cake.
It's great mod wise. You can get a lot of pre-made kit such as window panel, thermometers & drive coolers. There's also a load of mod examples to follow on various websites.
Apart from the cost (but you get what you pay for), the only things I can fault it on are that the aluminium can dent quite easily. My modem got knocked off of my desk (less than 30cm drop) and put a nice little 'scar' on the top panel.
The only other thing I can think of is that traditional beige (and in a lesser case, black) drives are a little unsightly (if you considder that a prob - I don't). Lian-li sell colour-matched bezel panels but only for a limited range of drives. They also only stick on top of the existing drive cover, so don't replace the buttons & vol dial etc.
There are different versions of the 60 out there - you might not get the type thats on their website. The latest one (I think) now comes with a fan in the top panel as well as USB2 ports & an exposed front fan speed switch.
P4 2.8 ~ Tt Volcano 7+
Gigabyte 8IHXP ~ 512mb RDRAM
Geforce 4 Ti4800 ~ Audigy 2 Platinum Ex
3x IBM 120GB 120GXP (Striped)
Maxtor 160GB DiamondMax 9+
Plextor 4012A ~ Pioneer A104
Lian Li PC65 ~ Enermax EG465AX
