Backlighting a digital LCD Thermomoeter.
Postby Starbuck15 » Wed Dec 18, 2002 6:14 pm
Hey all, I'm sort of leaning towards getting a Lian-Li T4B Digital Temperature Sensor if I can find one in celcius. My question is this, is there anyway to mod it to be backlight and to run off my PSU (I doubt the button cell batterys could power it backlight as well). Thanks!
-Starbuck
Visit my Homepage and Ben 10 Games here
Hey I'm a GEEK and I'm proud of it!
Starbuck15
Postby atang1 » Sat Dec 21, 2002 4:52 pm
If you know how to use LED; and expose the edge of the glass on your LCD, you got it made. Some people like the blue background with expensive blue LEDs. Yellow LED is nice too. Green is very bright. Red is very common LED, but maybe not bright enough.
LEDs are best limiting the current to 10 ma using 5vDC with a resistor.
atang1
Postby Starbuck15 » Sat Dec 21, 2002 5:01 pm
Thanks atang1. So you're saying that I need to expose the LCD glass and shine a LED through it? If that's right, how would I power the LED? Would I need another board or could I solder the LED's onto the LCD's board? And how would I power it all from my PSU? Or do LED's take up little enought power that I wouldn't need to.
-Starbuck
Starbuck15
Postby Hardware Junkie » Fri Jan 10, 2003 11:34 pm
I think you'd have a hard time finding a 5 or 12 volt LED....you'll have to play around with resistors to get it around 2-3 volts max.
Return to System Modification
