It is currently Thu Aug 13, 2020 3:17 am
PostPosted: Tue Jun 30, 2015 12:13 pm
This is the case mod I did for Fractal Design's event in Computex. The Define S chassis allows you to mount three 120mm or two 140mm cooling fans directly behind the bezel. This feature allows more interior space for larger radiators or push-pull fan configurations. The bezel's ventilated sides provide sufficient airflow for the factory default fan locations configurations. Opening the front of the bezel will improve airflow even more.
Supplies & Tools Needed for this Case Mod:
1. 3M Scotch 233+ Green Professional Masking Tape,
2. 12" Measuring Square and Pen or Pencil
3. Dremel or Rotary Tool with Reinforced Cutting Wheels,*
4. Jigsaw with 18 TPI or higher Bi-Metal cutting blade
5. Hand File
6. Medium Grit Sandpaper or 3M Red Scotchbrite pads,*
[img=]http://mnpctech.com/images/thumbnails/280/183/detailed/1/3m_red_scotchbrite_pad_37447_07447_mnpctech_ya8s-xh.jpg[/img]
7. 24" x 12" Round Modder's Mesh Sheet,
8. 3M ScotchWeld DP-190 Two Part Epoxy with Applicator Tip
9. Wire Clip or Tin Snip (Optional)
10. PETG Tube for PC Liquid Cooling. $.99 per 12" long tube, 1/2" OD x 3/8" ID PETG clear tube for Custom PC liquid cooling loops offers the same clear quality as standard Acrylic with an excellent impact strength and easy bend-ability.
PETG Clear Tube works with these 1/2" hard line compression fittings that include,
Alphacool HT 13mm OD hard tube
Monsoon Free Center Hardline Fitting - 3/8" ID x 1/2" OD
Monsoon Chain Gun Hardline Fitting - 3/8" ID x 1/2" OD
Primochill Ghost Hardline Fitting - 3/8" ID x 1/2" OD
Primochill Revolver Hardline Fitting - 3/8" ID x 1/2" OD
The Define S bezel is factory molded from ABS plastic, which is very durable and resilient to cracking. Removing a majority of the face plate didn't effect overall rigidity.
The backside of the bezel shows it's simplicity in design.
The first step is to cover the bezel with 3M Scotch 233+ Masking tape. This allows you to write measurements onto the bezel and protects it from being scratched by the Jigsaw.
Measure and mark off the portion of material you wish to remove. This cut-out will have 1" bordered frame of material remaining. Put on your Safety Glasses and use Rotary Tool with cutting wheel to make incision cuts in each corner. This will allow you to use a Jigsaw to make the long straight cuts efficiently.
Use Jigsaw with 18 TPI or higher Bi-Metal cutting blade to make the long cuts as straight as possible.
After finishing all of the cuts with the jigsaw, use a hand file and medium grit sand paper to clean and fix all of the edges.
Inspecting progress before moving onto the next stage.
These are two of the multiple mounting pegs on the backside of the bezel. We've chosen to remove the inner facing base support of each peg with a Wire cutter, so the mesh can be cut as rectangular piece. This step isn't required if you cut the Modder's Mesh sheet to fit around each mounting peg.
Use medium sand paper to smooth over the surface after cutting the one side of each peg base.
The Define S bezel's new intake grill will be cut from a 24" x 12" sheet, http://mnpctech.com/case-mods-gaming-pc-liquid-modding-custom-computer-mnpctech-overclock-cooling-fan-grills/modders-mesh-perforated-aluminum-steel-honeycomb-grill-intake-front-fan-slotted-diamond-round-hex
This material is 22 gauge perforated plain steel. 5/32" holes 3/16" staggered centers. 33 holes per square inch.
It's great for creating custom fan guards, grills, and cooling vents like this. It does need to be painted or clear coated otherwise it is a bare steel and will oxidize over time.
The mesh grill will be attached with 3M Scotch Weld DP-190 two part epoxy with mixture applicator attachment.
Place bezel on it's face. Apply the epoxy with it's applicator over the mesh overlapping the back of the bezel. It will ooze and sink into the individual holes of the mesh.
Use c-clamps or spring loaded clamps to hold the mesh in position as it cures for 24 hours.
Place some heavy objects on the mesh. This will prevent the mesh from bowing or warping as the DP-190 epoxy during it's 24 hour cure time.
The bezel will be ready to handle 24 hours after the epoxied mesh has cured.
PostPosted: Tue Jun 30, 2015 12:14 pm
Fractal sent their new Venturi HP-120mm PWM fans....Very nice! Fluid Dynamic Bearing, RPM 1800, 61.4 CFM @ 31.7 DBA
the front intake grill will be clear coated, I like the Silver look. Next stage modifying the right side panel with window for the SSDs, cnc machined SSD covers
We've gotta see the billet SSD covers, right?
PostPosted: Wed Jul 01, 2015 9:04 am
The chassis and exterior was painted House of Kolor Kandy Blue with Matte Clear finish, so it looks anodized. The paint and side panel design was inspired by the Swedish Supercar, Koenigsegg Agera R
SSD with LEDS
PostPosted: Thu Jul 02, 2015 1:53 pm
Final photos of my Define S build taken by Fractal Design's Office in Taiwan
