liquid cooling kits or homemade liquid cooling?
Postby charibdis » Tue Nov 26, 2002 9:28 am
I've been trying to find a good water cooling kit but I can't seem to find any in Canada, anybody know where I could possibly find some up here? I saw the swiftech kits, they look ok, but it's expensive ennough.
also has anyone attempted a homemade version of liquid cooling. What's the minimum GPH the pump needs?? I wonder if it can be made cheaper than buying a kit? I may just opt to buy that parts sperately. ??
charibdis
I'd like too see that!
Postby gudiniho » Thu Nov 28, 2002 4:30 pm
I'd like to see a homemade cooling kit. BE VERY CAREFUL! just follow this equation that took months of scientific research to find!
H20 + COMPUTER PROCESSOR = :x
gudiniho
Postby charibdis » Sun Dec 01, 2002 12:04 am
There has to be something that's easily obtainable that wouldn't cause a problem. I've always thought of suspending the pc upside down. (that way if it leaks it leaks onto the floor not onto the mobo)
charibdis
Postby Nads » Thu Dec 05, 2002 9:16 pm
Go to www.directron.com. Look under cooling and you should find something there. Also, dont be afraid to search it out on ebay. Ive noticed several kits for sale there as I am thinking of doing this myself.
Nads
Return to System Modification
