It is currently Wed Jan 22, 2020 10:31 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Aug 08, 2009 2:19 pm
Brad is drawing out the stencil for the right side panel artwork
PostPosted: Mon Aug 10, 2009 2:14 pm
The stencil for the bezel door and right side panel are finished.
PostPosted: Tue Aug 11, 2009 2:58 pm
Airbrushing the front bezel
Flesh tones
PostPosted: Wed Aug 12, 2009 11:55 am
Airbrushing more details on the front bezel door of the Silverstone tj10
PostPosted: Thu Aug 13, 2009 2:52 pm
The front bezel door of the Silverstone tj10 is finished
Image Image Image
PostPosted: Fri Aug 14, 2009 4:26 am
Started assembly of the chassis yesterday. All of the silver aluminum and steel parts were painted Ford Blue.
PostPosted: Fri Aug 14, 2009 3:21 pm
working on the right side panel artwork
PostPosted: Mon Aug 17, 2009 7:24 am
5x 120mm Noise Blockers for the Silverstone tj10 chassis
These fans are 1250 rpm, 51 cfm @ 19dBA. Voltage range is 4.5 to 13.8.
Bearing life at 140,000 hours with 6 year warranty!
I love the vibration dampening corner design
PostPosted: Mon Aug 17, 2009 3:25 pm
Black Anodized Aluminum 120mm Fan Grills
http://www.mnpctech.com/Computer_Billet_Fan_Grills.html
PostPosted: Tue Aug 18, 2009 4:40 am
Artwork progress for the right side panel
