It is currently Tue Oct 23, 2018 4:07 am
PostPosted: Thu Jun 11, 2009 3:55 pm
This will be another Insane Case Mod by Mnpctech.com
The CM Storm's Sniper and Scout gaming pc cases have side panels that are interchangeable, you can use the right panel on left side and vice versa. Normally the Scout comes with a window panel, but Cooler master sent me a sample with no window panel to play with :D This is a great opportunity to make my own custom "Scout" window!
I applied scotch brand painter's tape so I could draw the new window design. To compliment CM Storm's military theme for their cases, I'm incorporating a "Targeted" 120mm machined aluminum fan grill
Before cutting out the window, I'm using a 4.5" hole saw to cut the hole for the "Targeted" grill and 120mm cooling fan.
Hole saw attachments sizes for computer cooling fan holes
For cutting fan holes in acrylic and metal.
80mm = 3” hole saw
92mm = 3.5” hole saw
120mm = 4.5” hole saw
Video Guide To Using Hole Saw Attachments For PC Modding
To cut the window in the Scout's panel, I first use 1.5" reinforced cutting wheel with my Dremel to make the first cut in the panel, this intial cut always me to use my Jigsaw with 18TPI cutting blade to cut the entire panel more efficiantly.
Using Jigsaw with 18TPI cutting blade to cut the entire panel.
Once the window is cut, I drill 1/4" holes so i can use #10 5/8 fan screws for mounting the 120mm fan and "Targeted" 120mm machined aluminum fan grill in the side panel.
I'm touching up the exposed bare steel made after cutting the panel with Matte Black enamel, instead of using u-channel window molding
(Yes, this case is for the next CaseModBlog Giveaway!)
ah yes! Super strength adhesion from Scotch #4010 clear tape. Used for mounting windows in computer cases.
http://www.mnpctech.com/scotch_4010_tap ... _gods.html
Red Transparent Acrylic from Delvies Plastics, http://www.delviesplastics.com
I'm using the "Targeted" 120mm custom fan grill, it's cnc machined aluminum!
Since the "Targeted" grill is aluminum, it requires a different type of paint and preparation before I can paint it. Scuff the surface first with a red scotch brite pad, (or med grit automotive sandpaper) then wipe off the grill with a tack cloth.
I like to use SEM brand "self etching primer" because it provides the best paint adhesion to bare metal surfaces. You want to apply a good enamel paint like "RUST TOUGH" by Krylon.
I allow the paint 24 hours to cure.
PostPosted: Fri Jun 12, 2009 8:59 am
Thanks guys!
I really like how this new window looks.
PostPosted: Mon Jun 15, 2009 8:27 am
Saturday morning at the shop
PostPosted: Mon Jul 06, 2009 6:04 pm
Great work on that case Bill :wink:
THRASHER2's benchmark scores
Project T2's Spinner Case
