It is currently Sat May 30, 2020 11:31 pm
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Sun Sep 27, 2009 7:35 pm
The background glows! Brad applied House of Kolor's "Kosmic Glo" Glow In The Dark Green, technical date sheet
PostPosted: Mon Sep 28, 2009 10:26 am
Grey "weathered" F/X airbrushed onto portions the Mp40 handle and bolts surrounding the window panel
top I/O plate
PostPosted: Mon Sep 28, 2009 5:26 pm
More progress on the Wolfenstein side panel
PostPosted: Tue Sep 29, 2009 12:07 pm
The last details are sourcing an HD (emailed Nate on that) Optical drive, Monitor which I should have and Brad wants to paint the Razer Lycosa KB. Then we can install her guts and Wolfenstein game. Yes, I've held out on playing it.
PostPosted: Tue Sep 29, 2009 3:06 pm
YAH!!!
PDT_Armataz_01_42 PDT_Armataz_01_42 PDT_Armataz_01_42 PDT_Armataz_01_42
Let's get rolling!!!!
PostPosted: Wed Sep 30, 2009 10:07 am
Thank you! and the Panel is finished.
PostPosted: Thu Oct 08, 2009 8:43 am
I've installed one of the I've installed one of the 120mm "Black Gear" Fan Grills on the NZXT 1200W PSU for the Wolfenstein PC, we recorded a guide to making rust effects for PC & Case Modding while E.E.L. Ambiense was at the workshop
Image]120mm "Black Gear" Fan Grills[/url] on the NZXT 1200W PSU for the Wolfenstein PC, we recorded a guide to making rust effects for PC & Case Modding while E.E.L. Ambiense was at the workshop
PostPosted: Sun Oct 11, 2009 12:45 pm
LG DVD drive painted Matte Black
4010 3M adhesive tape, Grey
Tiny rubber foot I found in the junk drawer. No idea what it was from
Sanding the optical drive switch, Foamy may tell me this was unneccessary..lol
08061 trim and emblem adhesive by 3M, compliments of Foamy!
PostPosted: Mon Oct 12, 2009 6:08 am
Mnpctech sells the Clear version of the Scotch brand Heavy Duty clear tape #4010 used for mounting the 5.25 face plate on the drive
PostPosted: Mon Oct 26, 2009 1:13 pm
The HD is enroute! so we can install the system finally...hehe. We should have another update soon!
