It is currently Mon Mar 30, 2020 5:58 pm
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Mon Jul 06, 2009 1:55 pm
Heres the Mamba mouse progress, Brad gave it the pose of "I WANT YOU" taken from the Uncle Sam recruiting poster used extensively during World War II.
it needs to be cleared and buffed out today.
PostPosted: Wed Jul 08, 2009 10:40 am
The Razer Mamba Wireless Laser Gaming Mouse is finished!
PostPosted: Tue Aug 18, 2009 5:03 pm
I've been wanting to do more with the handle. I've decided to make the carry handle look just like the Mp40 gun from the game.
MP40 from new Wolfenstein game
MP40 airsoft gun
Airsoft gun dismantled
Power button will be in the barrel (22mm Lamptron switch with Red led)
PostPosted: Fri Aug 21, 2009 5:46 pm
performance-pcs was out of stock on the red dot vandal switch, so I ordered from FrozenCPU.com They have option for 2ft wire connection (pre-wired too) so that will save some time for me..nice!
I mounted a toggle switch in place of the Mp40's trigger
PostPosted: Fri Sep 04, 2009 1:49 pm
I'm routing wires from the bottom of the Mp40's clip into the chassis, made a 7/8" hole and capped it with a 22mm - 16mm reducer
22mm to 16mm reducer for vandal switches (made for performance-pcs)
PostPosted: Wed Sep 23, 2009 6:34 am
Wolfenstein project update, laying out mural of this screen shot from Wolfenstein on right side panel
PostPosted: Fri Sep 25, 2009 2:36 pm
while Brad rawks out the panel, I'm finishing the Mp40 handle. I'm skipping the gauge idea so we can get this project done...lol
PostPosted: Fri Sep 25, 2009 3:15 pm
Clever! The toggle "trigger" makes the gun go pa-pa-pa!
Thought it was gonna turn the inside the case lights on. Well, it did turn lights on, but...
8)
PostPosted: Sat Sep 26, 2009 3:57 am
Thanks for the great comment, I need them so I can finish this project and move onto other ones this week!
meanwhile.. in Brad's paint booth. He continues working on the background. Hes also trying out that glow in the dark paint again, but more on that later!
PostPosted: Sat Sep 26, 2009 1:02 pm
more progress on the airbrushing
