It is currently Sat Mar 28, 2020 1:57 pm
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
PostPosted: Sat Jun 13, 2009 12:57 pm
and a big Thank you! to Motherboards.org for sponsering the Wolfenstein PC Project with a new Gigabyte GA-MA790FXT-UD5P Motherboard!
Gigabyte's Product Spec page
http://www.gigabyte.us/Products/Motherboard/Products_Overview.aspx?ProductID=3007
PostPosted: Sun Jun 14, 2009 1:54 pm
THRASHER2's benchmark scores
Project T2's Spinner Case
PostPosted: Mon Jun 15, 2009 4:28 am
Here are a couple photos of the HSF that Thermalright sent us.
They sent us one of their silent fans and fan clips.
Here you can see the fan clipped to the Heat Sink.
Thanks again to Thermalright for providing such a great cooler for this system.
PostPosted: Mon Jun 15, 2009 11:35 am
Nate re-assembled the 4890 with it's custom painted shroud yesterday
PostPosted: Mon Jun 15, 2009 4:11 pm
Our MB arrived today! Lets take a closer look at the Gigabyte GA-MA790FXT-UD5P. Most importantly, will the monster Thermalright fit?.... the answer is Yes!, with 1" to spare. However, You cannot install the Corsair Dominator with their heatsink in DDR slot #1, the front of the Thermalright overlaps
1" gap between Thermalright and NZXT 1200 PSU.
PostPosted: Mon Jun 15, 2009 6:04 pm
Bill can you put the fan housing on the other side of the CPU cooler and flip the fan to push the air out the back?
PostPosted: Tue Jun 16, 2009 4:26 am
hmmm... sandwich action eh? I will try it
I'll probally do something with the heat sink shroud, paint it and swap out the Thermalright fan (63.7CFM @ 28.0 dBA) to a Cooler Master new R4 120mm cooling fan with 69-90CFM and 19-30dBA.
PostPosted: Tue Jun 16, 2009 3:19 pm
I swapped the 120mm fan to the rear of the Thermalright HSF, pulling air through the fins to the rear exhaust.
PostPosted: Tue Jun 16, 2009 7:06 pm
The top handle for the Panzerbox is finished and ready for paint.
From concept to reality.
PostPosted: Wed Jun 17, 2009 3:50 am
Painting it Flat Black to match the case. The cross drilled holes will remain bare aluminum.
