It is currently Sat Sep 22, 2018 9:40 am
PostPosted: Mon Nov 11, 2002 10:44 am
I recently put a fan on the side of my computer (cut the case and put in a fan) but there is a rather serious problem. Dust!
There is a whole lot of dust getting in. I have to clean my computer's insides every week. I am scared :cry:
What do I do?
Someone recommended air conditioning filters, will these do the trick?
PostPosted: Mon Nov 11, 2002 11:53 am
At the cost of a little airflow you should put a thin piece of foam on the exterior of the intake fan. This should be under the fan grill, if you have one. This foam filter would be easy to cut into size and should be easy to clean.
The other option is to keep the fan out of a dust prone environment. This may involve actual house cleaning, however... :o :)
PostPosted: Mon Nov 11, 2002 4:21 pm
House cleaning :?: i thought that was a bad word here :lol:
Gerald Ford (1913 - 2006)
PostPosted: Tue Nov 12, 2002 5:46 am
Fan filters are a good way to keep the dust out. You can even get them in multiple colors if you have a color theme to your computer.
Check this site out:http:
//www.tweakbox.com/fanacess.html
There are other sites (most of them are cheaper) but this is a good start
Cheers
--Diplomacy is the art of saying "nice doggy" until you can find a rock.
