It is currently Fri Feb 21, 2020 6:51 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
PostPosted: Wed Jul 18, 2007 8:34 pm
I Drilled all the holes for the Panel
Its time for some 600grt wet sanding :haha:
Finished all the sanding
I started to put all the Bling back together ;)
PostPosted: Wed Jul 18, 2007 8:35 pm
I installed the Upper frame and the Spinner (It Looks SWEEEET)
I assembled all the pieces to see how they would lined up
The panel is sticking out because its temporary installed
I almost forgot the Memory
I bought some Sweeet Patriot 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400
The SPINNER in ACTION!!!!! :evil:
http://smg.photobucket.com/albums/v629/THRASHER2/Worklog/?action=view&current=DSCF0024.flv
Template for cutting the Plexi
I love a Jigsaw with a Smooth Wood blade (Cuts like butter)
Clear and UV windows
PostPosted: Wed Jul 18, 2007 8:36 pm
Installed the UV window (Test Fit)
The spinner will be hooked up to this
http://www.xoxide.com/remote-12vdc-relay-kit.html
**HOLY CRAP** Super Project Update
I finnialy got my Powder Coated back from the Painter after weeks of DRAMA :evil:
Its Christmas
This Stuff is SWEEEEEEEEEEEEET!!!!
Side View
Up Close View "BLING"
PostPosted: Wed Jul 18, 2007 8:37 pm
White with Metal Flake is KICK ASS !!!!!
BLING!!!!! I Rivet that sucker and only messed up once :laugh:
PostPosted: Wed Jul 18, 2007 8:38 pm
I had to sand down part of the Fleet tabs to fit the Case. :laugh:
Just look at it BLING! :tongue:
Here is the pieces together :thumbsup:
PostPosted: Wed Jul 18, 2007 8:39 pm
And it Has begun :evil:
I started The Sleeving and Soldering the Switch Wires and the LED's up.
