It is currently Fri Feb 21, 2020 8:17 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
PostPosted: Wed Jul 18, 2007 8:24 pm
Here is a pic of the side panel that i drilled the holes for the Spinner bracket.
Bracket mounted with macking tape removed.
The Spinner is Mounted :haha:
More on the way............Stay tuned :excited:
PostPosted: Wed Jul 18, 2007 8:25 pm
Watch out the Madman is at it Again :haha:
A little taping off and sizing up the Holes :shades:
And the work begains :scared:
PostPosted: Wed Jul 18, 2007 8:26 pm
BAM!!!!!!
I made all the cuts on the Panel (Reset switch/Power Switch/Switch Panel and Spinner Hole)
Installed the Bling to see how it fits (WOW)
Front panel with the switches up
Close-up view of the BLING!
PostPosted: Wed Jul 18, 2007 8:28 pm
Here is another Pic of the BLING installed on front of the Case.
Here is the Modded LCD fan controller done by Twisted
[quote=Twizted]It looks better IRL as the camera kinda makes it look orangish but it looks good for sure;)
Image[/quote]
Stay tuned for the next weeks episode (AS THE SPINNER TURNS) :haha:
PostPosted: Wed Jul 18, 2007 8:31 pm
Here is the latest updates on the Spinner Mod :blurp:
Ok.....I needed to cut the small spinner housing
First look
I cutted the spinner housing down to fit into the Case body
Here is where i was marking the holes to be cut
T2 in Action :haha:
Checking the cuts i just made (Test Fit)
BAM!!!!
Isn't it pretty :blurp:
Close-up of the cleaned up cuts :shades:
Off to the back of the case for the 80mm fan test fit
I installed some U-Channel Trim Molding on the 80mm fan holes (and did a Grill test fit)
BAM!!!! I LOVE IT! :excited:
More to come...........Stay tuned :thumbsup:
The Mod Garage project is finished for now (Thank God that's Done)
I have time for the Spinnner Mod Now :grin:
Ok.....Back on track
First up
Cleaning up the Oval hole where the Power Switch goes.
(Sorry for the Pic) Damn work camera :sad:
A little work and BAM!!! (That Crap dries Quick)
PostPosted: Wed Jul 18, 2007 8:32 pm
I was checking out the Spinner side panel (DAMIT! the upper cut was to High to the Edge)
Lucky ...I have another Case with that side Panel.
Here are the two Panel together
I had another sweeet idea :haha: (Added a chrome Frame to the top)
The layout for the Cut (Alot of corners) :eek:
Super Update!!!!!
I am upgrading the Cpu/Mobo and Video card for this Project :shades:
My SAPPHIRE PURE Innovation PI-A9RX480 MoBo came in Today
Cpu/Video Card to follow :drool::blurp::excited:
CPU Type: Athlon 64 FX/Athlon 64/Sempron
DDR Standard: DDR 400 (PC 3200)
Dual Channel Supported: Yes
FSB: 1000MHz Hyper Transport (2000 MT/s)
Maximum Memory Supported: 4GB
Number of DDR Slots: 4x 184pin DDR
PCI Express x1: 2
PCI Express x16: 1
PCI Slots: 2
South Bridge: ATI SB450
Model #: PI-A9RX480
Small update :thumbsup:
I ordered some new parts for the project. w00ts :excited:
SAPPHIRE Radeon X850XT 256MB GDDR3 PCI Express x16 Video Card
$119.99 ($89.99 after $30.00 Mail-In Rebate)
PostPosted: Wed Jul 18, 2007 8:34 pm
The MaD Man is back at work :haha: (7hours of some sweeet modding)
I did a ruff cut of the upper Square section
Cleaned up all the cuts
Modding In [url="http://smg.photobucket.com/albums/v629/THRASHER2/?action=view&current=ActionMan.flv"]Action[/url]
