It is currently Tue Mar 26, 2019 5:39 pm
PostPosted: Fri May 24, 2002 2:37 pm
Drunken Master
http://www.motherboards.org/articlesd/motherboard-reviews/1175_1.html
Let us know what you think!
PostPosted: Fri May 24, 2002 3:50 pm
a 94 score, sweeeet :D nice review, although in reading the review I found some inconstancies with regards to overclocking. doc said
Quote:
I was only able to increase the FSB to 143MHz a fact I thought was a bit disturbing as all their other boards were stable at much higher frequencies. This is moderate overclocking and by no means the best available on the market
now in another review found here http://www.amd3d.com/review/a7v333/index.htm it seems like they were able to achieve much higher overclocking results from an Xp1600+ to an Xp 2000+ in one of there pictures you can see the board running at 165mghz am I just reading this wrong or did they do something to the board to achieve this high of an FSB Image and then with regurds to voltage limitations
Quote:
In order to achieve stable results I also had to increase the CPU voltage from 1.75v to 1.85v and I think with more voltage options I could have achieved better results
yet there is this review here
http://www.tweakers.com.au/articles/motherboard/asus_a7v333/page5.asp which they state
Quote:
This board was made with overclocking in mind - unlimited VCORE range, and 1MHz increments upto 227MHz, both of which should make the A7V333 a real challenge for overclockers.
why such huge differences? i usually disregard most reviews in favor of the ones from mb.org but in this case when two separate reviews come up with such large differences in regards to overclocking and the fact that i will soon be using this board, I have to ask the question. how come you could only reach 143fsb? if I missed something in your review [which apparently has happened before] please point it out. :)
PostPosted: Fri May 24, 2002 4:27 pm
So if the Asus board provides for just moderate overclocking what is the best board for heavy duty overclocking? Is the Soltek mobo a good choice?
PostPosted: Fri May 24, 2002 4:49 pm
EPox board is best for overclocking I believe.
Goddam mad dog!
PostPosted: Fri May 24, 2002 4:55 pm
Epox overclocked the most yes, but according to the review at tomshardware it also crashed the most. IM sticking with the asus, 165fsb with an adjusted multiplier is plenty when it comes to overclocking . going to over 200mghz fsb is just asking for trouble with your PCI and AGP frequencies.
PostPosted: Fri May 24, 2002 5:28 pm
Ok then let me rephrase the question. What KT333 board is best and most stable with overclocking?
PostPosted: Fri May 24, 2002 5:48 pm
asus seems to be ahead of the game with a7v333 especialy with the anti burn protection. that way if you do mess up your not going to fry your cpu
PostPosted: Fri May 24, 2002 8:37 pm
:arrow: :!: how about the shuttle ak35gt2 w/ ddr333 support (via kt333)? fsb can be tweaked to 225mhz and cpu voltage can be raised to 2.3volts- get it w/ raid and the highpoint controller can do 0, 1, and 0+1 config's- but how fast can it really go, i don't know- anybody?!?!?:
http://www.tweak3d.net/reviews/shuttle/ak35gt2/
PostPosted: Mon May 27, 2002 11:16 am
Lord Of The Realm
The CPU I was using only allowed me to change the voltage to that amount and still BOOT.
As I have stated time and time again that every setup and system is different and will yield different results.
The voltage is not unlimited either on the board I used it stopped 1.85.
I feel the ABIT KX7-333 offers better options overall for the overclocker and is a beter board for that job.
I am sure better results can be obtained with a different CPU as the one I have is not very OC friendly.
8) 8) 8) 8) 8)
PostPosted: Mon May 27, 2002 11:50 am
well thats good enough for me. so when i get my asus board back i will overclock it and see how far it goes with me.ImageImageImage
