How about an alphabetic glossary of terms?
Postby jackdav » Sat Aug 10, 2002 4:00 pm
It would be helpful for us newbies (i.e. the ones who come wondering "what's mobo mean? Oh, a motherboard, huhH What's that?")
Terms that I have wondered about have included
RAID
legacy products
DDR
overclocking
or .... maybe this already exists and I just haven't tripped over it yet...
Jack
________
silver surfer reviews
jackdav
Postby Toby B. » Mon Aug 12, 2002 1:53 am
DDR - Double Data Rate - Data is transfered twices as quickly. Instead of doubling the actual clock rate DDR memory transfers twice per tranfer cycle.
RAID - Redundent Array of Independent or inexpensive Disks - most often found on server side applications
Overclocloking - A process of running a processor at a speed faster then the officially specified speed by using a higher clock multiplier or faster bus speed.
Legecy products - Older computer producter that no longer have support.
Toby B.
Postby jackdav » Mon Aug 12, 2002 4:07 am
Thanks, Toby. WHat do you think about the idea of a glossary of terms? Seems like you've got a fair start on one right there.
Jack
________
Shoichiro Irimajiri
jackdav
Postby Toby B. » Mon Aug 12, 2002 9:26 am
jackdav wrote:Thanks, Toby. WHat do you think about the idea of a glossary of terms? Seems like you've got a fair start on one right there.
Jack
Sounds like a great idea. I will look into getting more addied the the list.
Toby
Toby B.
Postby Johnny Mnemonic » Mon Aug 12, 2002 9:47 am
http://www.pcguide.com/topic.html
Use the search option and you will always find more than you want to see....
0100101001001101
Johnny Mnemonic
Postby Toby B. » Mon Aug 12, 2002 9:52 am
Although some may find that helpful Johnny; What jackdav is looking for is a simplified glossary of basic terms (or at least to start)....
Toby
Toby B.
Postby jackdav » Mon Aug 12, 2002 10:46 am
"Use the search option and you will always find more than you want to see...."
Exactly!
Though you put it better than I would have.
Motherboards.org is a terrific resource and I wouldn't complain about a thing. Ever. But since suggestions are solicited, I thought a glossary might be a good way for a newcomer to find out what they want to without having to wade through a bunch of other terms they don't understand first. Things that I have learned about already but had to dig out (and may still have the wrong idea about?) .... like FSB .... striping ....... benchmark ... form factor ...... chipset ..... cache ...... clock rate .......... architecture ... SCSI .... how to pronounce SCSI ....... I/O .......... BIOS ..... CMOS .... etc etc.
The things that I think might make it a bad idea are the size of the undertaking (there are a lot of terms!) and the possibility of folks differing on definitions .... but then again, that could be fun.
~Jack
________
Chevrolet Corvette C4 specifications
jackdav
Postby Toby B. » Mon Aug 12, 2002 11:23 am
jackdav wrote:The things that I think might make it a bad idea are the size of the undertaking (there are a lot of terms!) and the possibility of folks differing on definitions .... but then again, that could be fun.
~Jack
This would be a major under taking but it is a very wise suggestion (I am going to PM a few of the necessary people whom have control of this site so we can get working on a detailed glossary.....Its gonna be a time consuming project, but it will be worth it if it helps people out.
Toby
Toby B.
Postby datektrader21 » Mon Aug 12, 2002 11:57 am
i can only think of two people you would have to pm, im just curios to know who else you are pming about this. it is a good idea.
datektrader21
Postby Toby B. » Mon Aug 12, 2002 2:20 pm
    1) Mobocop
    2) Tolemac
    3) Hardware Junkie ( your favorite one Datek :P )
Toby
Toby B.
Return to Motherboards.org Web Site
