How about a memory identification forum?
Postby ljerry4 » Tue Dec 17, 2002 3:00 pm
i.e. similar to the motherboard identification forum.
I'm forever having trouble figuring out in advance if a stick of memory I'm considering buying on E-Bay is going to work in a particular board.
ljerry4
Postby Toby B. » Wed Dec 25, 2002 12:14 am
Motherboard spec sheets/overview pages and or manuals usually will tell you exactly what is compatible with a motherboard in regaurds to RAM. If you are unsure what you have for a motherboard the you can post in the motherboard ID forum and we will do our best to figure it out...
Toby
Toby B.
Postby evasive » Sat Dec 28, 2002 8:20 am
The same holds true for the memory stick in question, post the link to where you saw it listed and we might be able to tell what it is and if it will work in your board.
Postby ljerry4 » Sun Dec 29, 2002 9:00 am
Thanks guys!
I appreciate the offers & plan to take advantage of them!
Since I like to learn as I go, I hope you'll also be willing to give a short "why" for your conclusions.
Thanks again; regards, Jerry
ljerry4
Return to Motherboards.org Web Site
