It is currently Tue Aug 21, 2018 4:09 am
 Post subject: P4T533 Review Request
PostPosted: Fri Dec 06, 2002 9:49 am
I was wondering if one of you motherboard.org people could write a review for the Asus P4T533. It is a fairly popular board (one that I have just purchased myself), and I would like to see what you guys have to say about it. Thanks.
Oh yeah... Also, I have heard some things about a motherboard that has an onboard audio "tube" that supposedly greatly improves sound quality. Is there any kind of input you have on this? It costs around $240, so I guess I'm wondering if it is really worth it.
Windows XP Professional w/SP2
Abit IC7-MAX3
P4 2.6Ghz 800Mhz FSB w/HT
1gb Mushkin Level II PC4000
ATI Radeon 9800 XT
SB Audigy Gamer
2x WD Raptor 10k rpm SATA w/ RAID-0
Sony DRU530A DVD-RW+RW
Zalman CNPS 7000-cu CPU Cooler
 Post subject: ASUS P4T533
PostPosted: Mon Dec 09, 2002 11:54 am
I have a very similar config as you listed. I am having stability problems right now. The machine will boot up just fine in XP Pro but after 4-6 hours just freeze up.
Config:
2 - Samsung 256MB RIMM4200
1 - Audigy Platinum Ex
1- ATI AIW 8500
2- 120GB WD on Raid 0
1 - 40GB WD on Primary IDE for boot up and programs
1- Enermax 430W PS
1- Klipsch Promedia 5.1
1 - Sharp LL-1820 LCD Monitor
1 - D Line NIC
I am really pulling my hair out as to what the problem is. With the ATI video capture and Raid setup, I can capture raw AVI DVD quality without dropping a frame. I am guessing that it is a bad memory stick.
PostPosted: Mon Dec 09, 2002 4:03 pm
I have problems with my system too. It doesn't freeze too much, but it randomly reboots a lot (mainly when I play games). I figured that it was just my cheap ass video card (Kyro 64mb), and was hoping the problem would go away when I get my Radeon 9700 Pro. Seems to happen more often when I have it overclocked too, which leads me to believe either the memory doesn't like the clock speed, or my video card doesn't like it.
Abit IC7-MAX3
ATI Radeon 9800 XT
SB Audigy Gamer
PostPosted: Mon Dec 09, 2002 9:09 pm
It's probably a bad power supply.
-Jem
PostPosted: Mon Dec 09, 2002 9:31 pm
will you read my post in tech support intitled "Random Reboots" please, Valour? It's a brand new PS (460W Logic). I bought it from an online company who assured me that it would be enough to power my system (I told them all the specs).
Abit IC7-MAX3
ATI Radeon 9800 XT
SB Audigy Gamer
PostPosted: Wed Dec 11, 2002 4:27 pm
I've been using this mb for about 3 months now.. its been very reliable... haven't had any huge hardware problems... only thing i suffer from is the same thing every other owner has is the sudden reboots
besides that... its been top notch..
i'm a avid gamer.. and i like tweaking system properties bios settings.. and the p4t533 has been very good for all of that... i've had a uptime for 2 - 3 weeks.. after all the os tweaking... and not a hitch... at the end.. the " sudden reboot" killed my uptime... oh wells..
if asus even address this problem i'll be a happy camper..
Intel 3.06b 533fsb
WinXP Pro Sp1 (Legit)
Asus P4T533 32bit / RAID
Rambus PC-4200 512 RDRAM
Ati Radeon 9700pro 128
1x WD 120 8mb HD
4x WD 250 8mb HD
Pioneer DVD-RW A04
Sound Blaster LIVE! Platinum 5.1
