It is currently Fri Sep 21, 2018 12:28 pm
 Post subject: integrated graphics
PostPosted: Mon Nov 18, 2002 10:08 am
I would like to see comparison of the nforce2 boards against other integrated solutions (ie xabre, sis, intel )
 Post subject: an idea
PostPosted: Mon Nov 18, 2002 8:25 pm
have know results but the best curent inigrated solution is the n-force but the 9000 mobility is mutch better (for labtops though)
P.S.
I wouldn't personaly use inigreated except to save a pretty penny as fare a i am conncerned exsternal is mutch better for now
PostPosted: Wed Nov 20, 2002 6:52 pm
I believe the Nforce2 is also but I would like to see actual numbers by a third party. Look at it this way, if the difference between nforce2 and a KT400A with xabre is only a few frames would you pay more for the nforce.
PostPosted: Thu Dec 12, 2002 4:31 am
The onboard video of the nForce ICP is that of a gForce 4 MX using up to 128 megs of main memory, I don't think there a better onboard video solutions out there at this time 8)
Wudce
PostPosted: Thu Dec 12, 2002 7:24 am
It's worth mentioning that not all nForce2 boards have onboard video.
-Jem
PostPosted: Thu Dec 12, 2002 5:55 pm
SPP=Non onboard video, ICP=board with onboard video :wink:
Wudce
PostPosted: Thu Dec 12, 2002 7:27 pm
I wasn't talkin' to you! :P
-Jem
PostPosted: Sat Jan 04, 2003 2:59 am
Yes I know ( Nforce2 with graphics may not be out to spring 2003) but this was just a suggestion for comparison of the newer boards with integrated graphics( I have looked at one with xabre graphics card that has it;s on onboard memory and doesn't use the system memory) and I thought it would be nice to see a side by side comparison.
BTW thanks for all comments
Lots of people don't know that a frame rate of 30 is adequate for most game and once the frame rate gets over 60 per second the human eye can not tell it.
