It is currently Fri Jan 18, 2019 6:40 pm
PostPosted: Fri May 10, 2002 9:08 pm
Was wondering if you have migrated all of your data over (if your using a new database). The search engine doesn't seem to return terribly accurate queries. When I use simple keywords, I would think I would get maxed out on the returns. Course the search in the previous forum wasn't that accurate either but it made you feel like you were getting alot with all of the hits.
From your current main page (of site), I clicked on the search icon at the top and it took me to the old search engine
http://216.98.145.234/forum/cgi-bin/ult ... ubb=search
From there I could click on the Forum home and it would take me to the previous forum (old)... it always seems to take a little time to work things out. Everything is looking really great though, keep up the good work! :) :wink:
PostPosted: Fri May 10, 2002 9:41 pm
Drunken Master
There is a link to the archives (the old forums) at the top of everypage in this forum. It is located under the title at the top of the page.
it is the link that says here.
