It is currently Fri Oct 19, 2018 2:01 pm
PostPosted: Thu Nov 16, 2006 4:48 am
just curious, if my mobo is able to take PC2700 ram but I installed a pc3200
is it backwards compatible? if so, would there be any Problems?
thank you in advance!
PostPosted: Thu Nov 16, 2006 10:01 am
Yes it is backwards compatible. It should not cause any problems unless the ram is not compatible with your motherboard. Some boards do not like certain brands of ram. Check with your motherboard manufacturer to see if it is compatible.
