Power Supply Voltages
A place where the most common PC questions are already answered for you.
Postby Waijun » Mon Jul 24, 2006 3:59 pm
i have recently installed an Antec SP-500 to replace an el-cheapo Suntec 430 watt power supply. The reson was the Suntec was old and only outputted 2.85V for my 3.3V rail. So now that I have installed the Antec, my Asus Probe monitors my 3.3V rail at 3.21V and my 5.0V rail at 4.9V. My question is whether or not thats okay or should i be worrying about the need to purchase a new motherboard soon.
my computer is a dinosaur in terms of gaming rigs by the way.
Waijun
Postby Roach412 » Mon Jul 24, 2006 7:49 pm
:mb_welcomeMB::
there's nothing wrong with those readings...you need to also take into account the fact that the probe might not be exactly correct.
you should also check the readings in your mobo's BIOS under the PC health option. that will probably give you the most accurate voltages.
you're good to go.
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
Roach412
Return to MBHW Q&A
