How Fast Is My Memory?
A place where the most common PC questions are already answered for you.
Postby Karlsweldt » Mon Jan 23, 2006 9:13 am
Reference chart for standard memory bus speeds:
The older 30-pin memory modules are considered obslolete. The 72-pin DIMMS are still used, but older PC-66 and later models are considered obsolete. A PC-100 can sub for a PC-66, as can a PC-133 sub for lower speeds. Not all modules are backward-compatible. Older memory types are still available, if searching the right source. There may be a voltage difference between older DIMMS and newer ones. Newer models use a lower voltage.
Standard memory speed configurations:
FPM SIMM..60ns@22 Mhz, 1 cycle per clock.. bus width 8 bytes, bus speed 22 Mhz, transfer rate 177 MB/s
EDO SIMM..60ns@33 Mhz, 1 cycle per clock.. bus width 8 bytes, bus speed 33 Mhz, transfer rate 266 MB/s
PC66 DIMM..10ns@66 Mhz, 1 cycle per clock.. bus width 8 bytes, bus speed 66 Mhz, transfer rate 533 MB/s
PC100 DIMM..08ns@100 Mhz, 1 cycle per clock.. bus width 8 bytes, bus speed 100 Mhz, transfer rate 800 MB/s
PC133 DIMM..7/7.5ns@133 Mhz, 1 cycle per clock.. bus width 8 bytes, bus speed 133 Mhz, transfer rate 1,066 MB/s
PC1600 DDR DIMM..DDR200@100 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 200 Mhz, transfer rate 1,600 MB/s
PC2100 DDR DIMM..DDR266@133 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 266 Mhz, transfer rate 2,133 MB/s
PC2400 DDR DIMM..DDR300@150 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 300 Mhz, transfer rate 2,400 MB/s
PC2700 DDR DIMM..DDR333@166 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 333 Mhz, transfer rate 2,667 MB/s
PC3000 DDR DIMM..DDR366@183 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 366 Mhz, transfer rate 2,933 MB/s
PC3200 DDR DIMM..DDR400@200 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 400 Mhz, transfer rate 3,200 MB/s
PC3500 DDR DIMM..DDR433@216 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 433 Mhz, transfer rate 3,466 MB/s
PC3700 DDR DIMM..DDR466@233 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 466 Mhz, transfer rate 3,733 MB/s
PC4000 DDR DIMM..DDR500@250 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 500 Mhz, transfer rate 4,000 MB/s
PC4300 DDR DIMM..DDR533@266 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 533 Mhz, transfer rate 4,266 MB/s
PC2 3200 DDR2 DIMM..DDR2-400@200 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 400 Mhz, transfer rate 3,200 MB/s
PC2 4300 DDR2 DIMM..DDR2-533@266 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 533 Mhz, transfer rate 4,266 MB/s
PC2 5400 DDR2 DIMM..DDR2-667@333 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 667 Mhz, transfer rate 5,333 MB/s
PC2 6400 DDR2 DIMM..DDR2-800@400 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 800 Mhz, transfer rate 6,400 MB/s
RIMM 1200 RIMM-16/PC600@300 Mhz, 2 cycles per clock.. bus width 2 bytes, bus speed 600 Mhz, transfer rate 1,200 MB/s
RIMM 1400 RIMM-16/PC700@350 Mhz, 2 cycles per clock.. bus width 2 bytes, bus speed 670 Mhz, transfer rate 1,400 MB/s
RIMM 1600 RIMM-16/PC800@400 Mhz, 2 cycles per clock.. bus width 2 bytes, bus speed 800 Mhz, transfer rate 1,600 MB/s
RIMM 2100 RIMM-16/PC1066@533 Mhz, 2 cycles per clock.. bus width 2 bytes, bus speed 1,066 Mhz, transfer rate 2,133 MB/s
RIMM 2400 RIMM-16/PC1200@600 Mhz, 2 cycles per clock.. bus width 4 bytes, bus speed 1,200 Mhz, transfer rate 2,400 MB/s
RIMM 3200 RIMM-32/PC800@400 Mhz, 2 cycles per clock.. bus width 4 bytes, bus speed 800 Mhz, transfer rate 3,200 MB/s
RIMM 4200 RIMM-32/PC1066@533 Mhz, 2 cycles per clock.. bus width 4 bytes, bus speed 1,066 Mhz, transfer rate 4,266 MB/s
RIMM 4800 RIMM-32/PC1200@600 Mhz, 2 cycles per clock.. bus width 4 bytes, bus speed 1,200 Mhz, transfer rate 4,800 MB/s
RIMM 6400 RIMM-64/PC800@400 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 800 Mhz, transfer rate 6,400 MB/s
RIMM 8500 RIMM-64/PC1066@533 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 1,066 Mhz, transfer rate 8,533 MB/s
RIMM 9600 RIMM-64/PC1200@600 Mhz, 2 cycles per clock.. bus width 8 bytes, bus speed 1,200 Mhz, transfer rate 9,600 MB/s
Edit: Some additional references..
http://www.2cpu.com/articles/44_1.html?25696&99369
http://www.interfacebus.com/memory_modules.html
http://www.crucial.com/library/quality_page3.asp
http://memory-chips.globalspec.com/
Postby ~PJ~ » Mon Jan 23, 2006 9:37 am
That's VERY handy. I'm forever having to frantically look up the equivalents.
TVM
Peace for its people,
Love in our lives,
Delight in the good,
Forgiveness for past wrongs,
And from now on a new start.
~PJ~
Postby Copper » Mon Jan 23, 2006 10:05 am
very usefull
Copper
Return to MBHW Q&A
