It is currently Sat Aug 18, 2018 6:25 am
 Post subject: My Temperature Is..
PostPosted: Mon Jan 23, 2006 9:04 am
Many of us wonder what the temperature equivalent is, between Celsius and Farenheit.. here's a quick chart for reference...
Equation from Celsius to Farenheit temperatures..
5° C. equals 9° F. plus 32 degrees.
You can also use the .5° C. to .9° F. ratio.
Celsius....(deg.)......Farenheit
100.........................212 (water boiling)
95..........................203
90..........................194
85..........................185
80..........................176
75..........................165
70..........................158
65..........................149
60..........................140
55..........................131
50..........................122
45..........................113
40..........................104 (upper limit of bodily stability)
35.......................... 95
30.......................... 86
25.......................... 77
20.......................... 68
15.......................... 59
10.......................... 50
05.......................... 41
0.......................... 32 (water freezing)
-05......................... 23
-10......................... 14
-15......................... 05
-20.........................-04
-25.........................-13
-30.........................-22
-35.........................-31
-40.........................-40
-45.........................-49
-50.........................-58 (too cold to think!!)
PostPosted: Mon Jan 23, 2006 12:30 pm
cool nice chart
Join team 33258 today!!
PostPosted: Tue Feb 14, 2006 12:51 pm
So what is an ideal range of temp a PC should be running at?
PostPosted: Tue Feb 14, 2006 1:59 pm
whatever it is that the manufacturer lists. :D
i like to keep my temps <40C but it's not necessarily a rule or anything. i think i'm just partial to seeing a 3 at the beginning of the temps. ??
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Tue Feb 14, 2006 3:37 pm
depends on the model of the cpu,
the new amd max die temps are 70c but the old ones used to be 95c
