It is currently Fri Oct 19, 2018 2:24 pm
Post new topic Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jan 21, 2006 9:48 am
EmilyB wrote:
evasive wrote:
EmilyB wrote:
DAVE185 wrote:
and disable guest postings
I ran the WindowsXP installation. Although I did see the F6 prompt. I could not see any guest postings :? On what screen of the installation does this appear?
posting 4 and 5 of this very thread, dear. look up...
Ok I think my point was overlooked :P
I was just addressing a seemingly disjointed post, which a noob may take as an instruction of the process. There was no quoting or referencing of anything, just a confusing statement. Surely it would be better to either put it in the Forums Problems forum or PM OllE?
well i would edit it to make a quote but since theres no edit option I guess I can't do that but will take your advice and pm olle
Join team 33258 today!!
PostPosted: Sun Jan 22, 2006 2:08 am
Quote:
Only if you are using two identical drives in a RAID setup, do you need specific drivers.
not true. it depends on the driver data base listed in your version of XP and the hardware your using. its a hit or miss thing you geek of here.
good luck
AJ
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
