It is currently Thu Sep 20, 2018 6:34 pm
PostPosted: Mon May 07, 2007 3:26 am
The Core 2 Duo E6600 costs 212 euros and the Core 2 Duo E6420 184 euros I will be using a Asus P5W DH Deluxe and some ddr2 800 ram.
Is it worth spending the extra 28 euros for the E6600?
PDT_Armataz_01_01
Asus P5W DH Deluxe
Intel 6420
2GB OCZ
Nvidia 7900GS
2x 320 Segate hdds
PostPosted: Mon May 07, 2007 5:02 am
in my opinion, it's only worth it if you don't overclock. if you plan on overclocking, then save the 28 euros (or put it towards better cooling)
People who have gone through Starfleet academy should be taught how to fix everything. Even a Roman aqueduct.
PostPosted: Mon May 07, 2007 6:01 am
Ok thanks for your thoughts. I might end up getting the E6420 PDT_Armataz_01_01
Asus P5W DH Deluxe
Intel 6420
2GB OCZ
Nvidia 7900GS
2x 320 Segate hdds
PostPosted: Sat Aug 04, 2007 7:16 pm
I'd go for the E6420. 8)
PostPosted: Sun Aug 05, 2007 1:18 am
I bought the E6420 a while ago its very nice It over clocks with my new motherboard to E6600 speeds with a 1 degree temperature increase :D Of course I bought nice Zalman heatsink which helps.
I havent really experimented how far I can overclock it yet as I dont have much that really uses so much cpu.
Asus P5W DH Deluxe
Intel 6420
2GB OCZ
Nvidia 7900GS
2x 320 Segate hdds
PostPosted: Sun Aug 05, 2007 6:25 pm
ROFLMAO. I didn't even notice how old that post was. :lol: Dang, guess the forums are getting a little slow after all. :(
You should be able to hit 3ghz quite easily @ stock voltage. Which mobo do you have?
PostPosted: Mon Aug 06, 2007 1:00 am
This is the one I have
http://www.asus.com/products4.aspx?l1=3 ... odelmenu=1 :D
It came with a few features that I dont use and there seem to have been lots of BIOS updates but it seems nice up until now. I am using the latest non-beta bios 2004
Asus P5W DH Deluxe
Intel 6420
2GB OCZ
Nvidia 7900GS
2x 320 Segate hdds
