monitors giving out when FSB gets a little too high
Postby psolas » Fri Mar 30, 2007 2:42 am
how do i get software to monitor and overclock pc?
I read through the 101 post above, but the links to the software it recommended were dead. i have an older pc i will practice on first to get the "feel", thanks in advance guys.
edit: new topic for new question
psolas
Postby ajrox » Fri Mar 30, 2007 9:42 am
i would start by reading as many posts in the OVERCLOCKERS ANONAMOUS forum that you can. there is an incredible amount of info on doing what it is your looking to do. be aware though, older hardware typically lacks the options and finesse that you find on newer hardware.
good luck
AJ
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
ajrox
Postby psolas » Fri Mar 30, 2007 5:14 pm
ok i took the plunge and upped my FSB's to 111. it went from a 1.7 ghz socket 478 to a 1.89 Ghz. i tried FSB 117 but then the monitors wouldn't load so i reset the BIOS to the originals and went back to 111. Is there anything i can do to get it higher without the monitors giving out. Maybe I need more RAM ? currently i have 1 gig ddr 400 ram in it, and have another gig in the mail from online retailer. i was plaanning on getting a cpu on ebay maybe a 3.0 or a 3.4 eventually but thought i'd try to up it in the meanwhile.
what can i do to up the FSB higher w/o losing monitor output?
i haave speedfan and at current 111 FSB the cpu is remaining around 28 degrees or less. when it intensified i've seen it get up to 38, and that after a few minutes when i opened everything at the same time, but it didn't go higher.
thanks is advance to those with more experience.
psolas
Postby psolas » Fri Mar 30, 2007 6:43 pm
mobo now at 113, this is it:
Operating System Microsoft Windows XP Home Edition 5.1.2600 (WinXP Retail)
Date 2006-03-07
Time 23:31
CPU
CPU Properties:
CPU Type Intel Pentium 4, 1917 MHz (17 x 113)
CPU Alias P68, Willamette, A80528
CPU Stepping C1
Instruction Set x86, MMX, SSE, SSE2
Original Clock 1700 MHz
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 256 KB (On-Die, ECC, ATC, Full-Speed)
CPU Physical Info:
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 42 million
Process Technology 6M, 0.18 um, CMOS
Die Size 217 mm2
Core Voltage 1.75 V
I/O Voltage 1.75 V
Typical Power 55.3 - 75.3 W (depending on clock speed)
Maximum Power 72 - 100 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 0 %
here is the CPUID info:
CPUID Properties:
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 1700MHz
CPUID Revision 00000F0Ah
IA Brand ID 08h (Intel Pentium 4)
Platform ID 0Eh (Socket 478)
IA CPU Serial Number Unknown
Microcode Update Revision 14
HTT / CMP Units 0 / 0
Instruction Set:
64-bit x86 Extension (AMD64, EM64T) Not Supported
Alternate Instruction Set Not Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Not Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
MONITOR / MWAIT Instruction Not Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
VIA FEMMS Instruction Not Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
Montgomery Multiplier & Hash Engine Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Supported
Enhanced Halt State (C1E) Not Supported
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Not Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
36-bit Page Size Extension Supported
Address Region Registers (ARR) Not Supported
CPL Qualified Debug Store Not Supported
Debug Trace Store Supported
Debugging Extension Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Not Supported
L1 Context ID Not Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Not Supported
Physical Address Extension (PAE) Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Supported
Time Stamp Counter (TSC) Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
etc info:
Motherboard
Motherboard Properties:
Motherboard ID 63-122-0000010-00101111-090806-INTEL$P4I6G122_P4I65G BIOS P1.30
Motherboard Name Unknown
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 113 MHz (QDR)
Effective Clock 451 MHz
Bandwidth 3608 MB/s
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 150 MHz (DDR)
Effective Clock 301 MHz
Bandwidth 2406 MB/s
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 75 MHz (QDR)
Bandwidth 301 MB/s
Memory
Physical Memory:
Total 1022 MB
Used 433 MB
Free 588 MB
Utilization 42 %
Swap Space:
Total 2459 MB
Used 303 MB
Free 2156 MB
Utilization 12 %
Virtual Memory:
Total 3482 MB
Used 737 MB
Free 2745 MB
Utilization 21 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
SPD
[ DIMM1: Transcend (1 GB PC3200 DDR SDRAM) ]
Memory Module Properties:
Module Name Transcend
Serial Number None
Module Size 1024 MB (2 ranks, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS)
psolas
