It is currently Tue Sep 25, 2018 9:36 am
PostPosted: Fri Jan 19, 2007 2:21 pm
Ok so i started my overclocking experience yesterday. I want to know when your FSB is 230 and you are running DDR2 does that make your ram run at 920? I have patriot ram running at 667 and upped my core speed form 2.41 to 2.76. is that ok for a beginner? what can i do to achieve a higher stable clock?
Current Build
Lian Li G70B
Thermaltake Toughpower 850W Sli 8800GTX
Intel Core 2 Duo E6600 4mb L2 2.4GHz
Bought Intel Core 2 Quad Q6600 2.4Ghz
eVGA 680i SlI Socket 775
Corsair 2GB (2 x 1GB) DDR2 800 (PC2 6400)
eVGA GeForce 8800GTX
Western Digital Raptor X 150Gb 10,000RPM
PostPosted: Fri Jan 19, 2007 4:22 pm
If you are running stable with those settings that's good but you must not make large movesin your settings the most important aspec is to ensure your temp's are not going to high, make sure you have temp warning turned on on your overclocking application.
PostPosted: Sat Jan 20, 2007 3:44 pm
ok thanks for the info. my temps at 2.76 were hovering around 53-57c. one more question. about my memory when the fsb is 230 does that mean that my ram is clocked at 920?
Current Build
Lian Li G70B
PostPosted: Wed Jan 24, 2007 11:06 am
its a theoretical number your looking at. the true, unadulterated clock is 230mhz. its the techno spin they put on it.
if your in the mid 50's C* @ idle, it is too high.
AJ
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
PostPosted: Thu Jan 25, 2007 12:13 pm
for real? dang. iight well ill try something different. thanks.
Current Build
Lian Li G70B
