It is currently Tue May 21, 2019 11:22 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Dec 29, 2006 7:34 pm
When I said "1:1", that refers to the divider ratio between the memory frequency and FSB frequency.
But, your BIOS doesn't do that. Show me what settings you tried to use on the memory when at 800mhz and tried to OC. And how much did you try to push up?
RIAA vs The People
PostPosted: Fri Dec 29, 2006 7:39 pm
Ok
CPU VOLTS 1.325
CPU CLOCK 343
FSB TERMINATION VOLTAGE 1.2
MCH VOLTAGE 1.25
MEMORY VOLTS 2.1
PCI-E CLOCK SET AUTO
SYSTEM MEMORY FREQ 800
TIMING 5-5-5-18
E6300 @ 2.81/1.325V
BIOSTAR P965 T-FORCE DELUXE
BFG 7900GS-OC
CORSAIR XMS2 PC6400 4X512
CORSAIR 520W/TRIPLE RAILS
WDC1200JC 120GB
ACRTIC COOLER PRO 7
SB AUDIGY SE 24BIT 7.1
PostPosted: Fri Dec 29, 2006 7:43 pm
Is 5-5-5-18 as high as you can go?
RIAA vs The People
PostPosted: Fri Dec 29, 2006 7:46 pm
no i can go up to 6-7-7 23
E6300 @ 2.81/1.325V
BFG 7900GS-OC
WDC1200JC 120GB
ACRTIC COOLER PRO 7
PostPosted: Fri Dec 29, 2006 8:34 pm
Try pushing the timings to the highest and see if it will post. If its stable, then keep cranking them down until it won't, then back them off a bit. Run some stability tests for a few hours.
RIAA vs The People
PostPosted: Fri Dec 29, 2006 9:55 pm
well this is the best I can get it to with out uping the volts
CPU 2.4
CPU VCORE 1.325
MEM SPEED 800
MEM VOLT 2.1 "STOCK IS 1.9"
TIMING 6-6-7-19
WOULD I BE BETTER OF AT 667 WITH TIMINGS OF 5-5-5-18 AND ONLY 1.8 VOLTS?
E6300 @ 2.81/1.325V
BFG 7900GS-OC
WDC1200JC 120GB
ACRTIC COOLER PRO 7
PostPosted: Sat Dec 30, 2006 1:30 am
Snake_Pliskin wrote:
CPU 2.4
CPU VCORE 1.325
MEM SPEED 800
TIMING 6-6-7-19
No, you're doing good. Feed it some more voltage and see if you can crank 5-5-5-18 out of it. If not, that's a good OC. The latency in actual nanoseconds is about the same right now as 667 at 5-5-5-18. So, you're not suffering in that area, and you have more available bandwidth.
RIAA vs The People
PostPosted: Sat Dec 30, 2006 1:45 am
SO add more than 2.1v to the ram wont that hurt it. It's stock volts are 1.9
I know you know what your talking about so if you say thats ok then I'll do it I have great cooling in my case so I dont think it would get to warm but I tried orthos at my current timings and had error in 31sec this is waht it said.
"Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 767 Time: 15
CPU: 2405MHz FSB: 343MHz [343MHz x 7.0 est.]
29/12/2006 10:45 PM
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
2:Beginning a continuous self-test to check your computer.
1:Press Stop to end this test.
2:Press Stop to end this test.
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
1:FATAL ERROR: Rounding was 0.5, expected less than 0.4
1:Hardware failure detected, consult stress.txt file.
2:FATAL ERROR: Rounding was 0.5, expected less than 0.4
2:Hardware failure detected, consult stress.txt file.
1:Torture Test ran 0 minutes 31 seconds - 1 errors, 0 warnings.
2:Torture Test ran 0 minutes 31 seconds - 1 errors, 0 warnings.
1:Execution halted.
2:Execution halted."
So is that because my timing are too loose or what?
EDIT/UPDATE: Well I tried 800 and all types of differnt timing and never good keep it stable unless I was at 2.0GHZ but my 3D06 Score went from 5830 to 5030 and my frame rate went down in games. So I'm at 5-5-5-15/667 at 2.4 I guess I need better ram?
E6300 @ 2.81/1.325V
BFG 7900GS-OC
WDC1200JC 120GB
ACRTIC COOLER PRO 7
PostPosted: Sat Dec 30, 2006 2:16 am
Yeah, you may need either better RAM or just a better OCing motherboard.
RIAA vs The People
PostPosted: Sat Dec 30, 2006 2:21 am
i swear you never sleep. :)
oh and here is my board and look what they get it to
http://www.anandtech.com/mb/showdoc.aspx?i=2871&p=4
I guess my ram sucks even though i though XMS was decently good
E6300 @ 2.81/1.325V
BFG 7900GS-OC
WDC1200JC 120GB
ACRTIC COOLER PRO 7
