oc a Asus A8N-VM
oc a Asus A8N-VM
Postby rayzor17 » Thu Aug 31, 2006 12:32 am
Hi all i am running this board with a 3200 athlon chip venice type i think
what is the simple way to clock it a bit i am complete novice at it so any thing would help
cheers
rayzor17
Postby Oylpann » Sun Sep 24, 2006 9:29 am
This from Anandtech -
The BIOS options were surprisingly sparse on the Asus A8N-VM CSM. As you can see, there really aren't any voltage adjustments at all - no vCore, vDIMM, or chipset voltage adjustments. The board supports AMD Cool'n'Quiet, but then has no means of adjusting multipliers in BIOS. The CPU clock is adjustable, but with a very limited range from 200 to 240. The point is that there are extremely limited means to really overclock the A8N-VM.
Looks like your only option would be to push the FSB up. Your really limited with no voltage adjustments.
Asus F2A85-V Pro
AMD A10-5800K APU @ 4.5GHz
8GB G. Skill 1866
550w PSU
Hyper 212 Evo
Oylpann
