It is currently Sat Sep 22, 2018 9:20 pm
PostPosted: Sat Aug 26, 2006 10:18 am
i just bought a ATI X1900XT and would like to know which overclocking tools are best for overclocking. i dont want to overclock that far with my card, just to X1950XTX levels.
Current Build
Lian Li G70B
Thermaltake Toughpower 850W Sli 8800GTX
Intel Core 2 Duo E6600 4mb L2 2.4GHz
Bought Intel Core 2 Quad Q6600 2.4Ghz
eVGA 680i SlI Socket 775
Corsair 2GB (2 x 1GB) DDR2 800 (PC2 6400)
eVGA GeForce 8800GTX
Western Digital Raptor X 150Gb 10,000RPM
PostPosted: Sat Aug 26, 2006 10:04 pm
I don't think that you can overclock your x1900xt to the x1950xtx speeds....DDR4 runs much fast then gddr3, so it would be really hard. I honestly don't see the point to overclocking an extremly high end card that much. Yeah, you will see slightly better performance, but not a ton.
PostPosted: Sat Aug 26, 2006 11:31 pm
BANNED!
I am on the same page with you. I think OCing that graphics card is kind of out of place. First off you arn't going to achieve 1950xtx levels with that card. The DDR4 will sail past it. If I were you I would leave it stock unless you can find a game that you can't run on high.
PostPosted: Sun Aug 27, 2006 4:11 am
Check out this link on how to OC. ATI video cards are great for overclocking. Espically te older 9800 Pro series to 9800 XT's
No matter what you do u will want to upgrade the cooling fan on the card.
http://www.nordichardware.com/Reviews/? ... ivelse=469
Here is how i OC my old 9800 to give u a idea of what your getting yoursef in to.
http://www.motherboards.org/forums/view ... light=9800
PostPosted: Sun Aug 27, 2006 9:01 am
dang your right it does have ddr4. haha good thing i got a high end card :o. ill leave the overclocking to you bw. thanks for making me see the light.
Current Build
Lian Li G70B
