Playtime...
Playtime...
Postby Tobyone » Thu Jul 27, 2006 10:24 am
Hi, after assessing my meagre student finances it has become apparent that a 64bit system is out of my immediate price range so i would like to overclock my existing pc.
Im running
ahtlon xp 2500+ (with heatsink and fan)
1 gig ram
asus a7n8x-x mobo
windows xp
xfx force graphics card (not a high spec one)
I read about the pencil trick for athlon chips and wondered if that was the best place to start?
also i can set my ram for aggressive, is that wise?
any tips or advice greatfully recieved as my pc seems sluggish in the extreme!
cheers, Tobyone
Tobyone
Postby Tobyone » Thu Jul 27, 2006 10:36 am
sorry, that should read athlon xp3000+.
Tobyone
Postby Beaner157 » Thu Jul 27, 2006 8:11 pm
what core is your processor?
what is it clocked at?
what type of ram do you have?
im sure we can drain some more power out of it just need to know what we are dealing with :wink:
AMD 6000+ @ 3.2GHZ
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
2 gigs (1 gig x2) GSKILL DDR 800 @ 4-4-4-12
MSI 8800GT 660/1900
160gig WD 3.0Gb/s
SB X-FI Extreme Gamer
ASUS M2N - SLI Deluxe
RAIDMAX Aztec Case
Beaner157
Postby Beaner157 » Fri Jul 28, 2006 12:19 am
well id start with small increases with your fsb, multiples of 3 should be right, umm what graphics card do you have?
also defaging your pc every so often will keep things running smooth.
your barton may be locked, so dont mess with the multiplier
AMD 6000+ @ 3.2GHZ
MSI 8800GT 660/1900
160gig WD 3.0Gb/s
RAIDMAX Aztec Case
Beaner157
Postby Tobyone » Fri Jul 28, 2006 5:48 am
hi, the cpu has a barton core (dont know what its clocked at) and the ram is ccl budget special ram (2 x 512). its not the best ram and im willing to upgrade if it makes a noticable difference.
will have to check what the graphics card is, although im willing to upgrade that too if it makes the difference. its an xfx tv out, with 128 ram i think.
how do you adjust the fsb?
and is the pencil trick messing with the multiplier?
cheers, T
Tobyone
Postby Tobyone » Fri Jul 28, 2006 9:41 am
cool, is there anywhere to find 'safe' amounts to overclock with? also is there anything possible with the ram...i wondered as it was mentioned in an earlier posting.
cheers, T
Tobyone
Postby Tobyone » Sat Jul 29, 2006 7:17 am
ok, i looked in the bios and couldnt find anything to adjust the bios. i changed the settings from optimal to aggresive and the pc wouldnt even load to bios!
i removed the soundcard and it booted normally. i changed the bios setting back to optimal and it worked fine with the sound card reinserted.
what should i look for to change the bios settings?
cheers, T
Tobyone
