It is currently Fri Sep 21, 2018 12:26 pm
PostPosted: Sun Jul 23, 2006 2:50 pm
Hey all...
I have my system upgrades running stable and I am ready to start playing with overclocking. I have another thread running for overclocking the processor...This one is for overclocking my Video Card. Here is my current setup:
ECS L4VXA2 Mobo
2.8GHz/533/512K Pentium 4 Northwood
1GB DDR400 Memory (currently running at DDR266 speed)
ATI Radeon X800GTO 256MB AGP 8x Video Card
---400MHz Core Clock
---980MHz Memory Clock
---256-bit Memory Interface
---12 Pixel Pipelines (no, the extra 4 cannot be unlocked on this card)
Western Digital 80GB 7200rpm 8MB Hard Drive
Cooling:
---5x 80mm case fans
---1x 120mm case fan
---1x CPU fan
---1x Video Card fan
---1x Dual-Fan hard drive cooler
I have downloaded ATI Tool to assist with overclocking the card.
There have been mixed reviews on this particular card (it's the Powercolor variant) as to what the maximum overclock is for the core. Some people have received a card that can overclock to 420MHz Core and some have been able to hit 475MHz Core. Seems that not a lot can be done with the Memory Clock regardless, though.
My main goal with this is to get Elder Scrolls IV: Oblivion running well. It runs quite smooth on this setup as it is, but I still get the occasional stuttering in the Wilderness.
I have never used an ATI-based Video Card before. Nor have I used ATI Tool for this reason. Any help I can get is greatly appreciated!
Thanks,
Jason
PostPosted: Mon Jul 24, 2006 3:34 am
Ok...
I decided to do a little tinkering since I wasn't getting any responses here. This is what I did and what I found:
1) I am running stable at 419.75MHz Core Clock--My video shut down and I had to hard reboot to get it back at 435MHz, so I figured this was a safe setting until I get some help.
2) The Memory Clock doesn't seem to like adjustments--When I attempted to make any changes at all, I lost video and had to hard reboot. I'm running stock until I get some help here.
Looking forward to hearing anyone's thoughts.
Thanks,
Jason
PostPosted: Fri Jul 28, 2006 9:02 am
i had the same problems with 9800pro. not the same card, but close. i could increase the core speed a fair amount, but with the memory anything more than 2MHz would cause trouble. not sure why. i'm also not very good at this stuff.
PostPosted: Fri Jul 28, 2006 12:33 pm
Hi, eatshawn...
Yes, it seems to be true for just about all ATI card. They seem to have the memory preset to the maximum speed that it will handle right out of the box. It doesn't seem to be a big issue, though. With the settings where they are at, Oblivion seems to be running fairly smoothly. I've only had a hiccup or two since the increase to 419.75MHz Core.
I'm also overclocking my processor slowly (that's in another thread), so that's probably helping as well.
Thanks,
Jason
