It is currently Thu Sep 20, 2018 6:27 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jul 31, 2006 7:12 am
Jason, I don't know very much about Intel boards or proccessors. Does the
BIOS use multilpiers? If it does you might want to raise the multiplier and lower the fsb until you get stock speed and slowly raise your fsb until machine won't boot or crashes. Then you could try raising the CPU voltage a notch and see what happens. I have done a Google search and it seems like this board is not the best for OC.
ASUS A8N32 Sli Deluxe
AMD Opteron 165
2 x 512 TEAM Group PC4800
ATI AIW X1800XL
2 x 74gig WD Raptors RAID 0
Pioneer 110D DVD+/-RW
PC Power & Cooling Silencer 750
PostPosted: Mon Jul 31, 2006 3:39 pm
Hi, MrMozart...
My multiplier is locked at 21x...Adjustment of the multiplier isn't possible with Intel processors (at least the generation that I'm working with). I wish it was.
I'll agree it's not the best for O/C...That's why I was hoping to just get a small boost (was hoping to hit 3GHz, but looks like I might be stuck at 2.9GHz)...But it's been an outstanding motherboard so far (the crash from needing a voltage bump was the first crash in 2 years since I built the machine), so I'm willing to deal with a lower O/C versus replacing the board.
Thanks,
Jason
PostPosted: Thu Aug 03, 2006 12:07 pm
some setups just dont over clock like you want. my XP 3000+ would only run 10mhz over stock and the 6600gt i had OC'ed really well.
my current CPU, an Opteron, over clocks like a madman. the default FSB is 200mhz yet it runs at 275mhz stable. this is on air BTW.
saw your thread about OCin' your video card. well same goes for those as well, sometimes they just are what they are. my current vidcard, a 6800GS, will unmask the 4 pipes and 1 vertex shadder but will not OC really. so, i would say research what it is you are trying to do and see what other peeps have used. follow thier examples. thats why i got an Opty :lol:
AJ
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
PostPosted: Thu Aug 03, 2006 12:25 pm
Do you have the option for RAM voltage? You may need to give the RAM more juice for it to be able to follow the CPU up through the speeds.
As for CPU voltage, if its too much it won't even try to boot. The CPU can protect itself in situations like that, so don't worry about it too much.
RIAA vs The People
PostPosted: Thu Aug 03, 2006 10:38 pm
Hi, all...
Thanks for all the information!
Here's the latest:
1) I was running stable at 169MHz FSB with a +2% increase in the core voltage. Then I had to reboot and got the BSOD.
2) I backed off to 168MHz FSB (still with the +2% core voltage) and booted up and ran just fine for 2 days and passed Prime95 and Folding ran just fine. Then I had to reboot and got the BSOD--again.
3) I backed off to 166MHz FSB (and dropped the +2% core voltage back to stock) and booted up and I am running just fine and can reboot with no issues.
Why would I run perfectly fine, pass all stress tests, then reboot and get "Error IRQ_less_than_or_not_equal_to" on the BSOD?
Now I can let this run for a couple of days, increase the FSB again and bump the core voltage and I'll run just fine---until I have to reboot. I'll pass all stress tests and Folding will run perfectly as will Oblivion, but upon reboot, I'll crash.
Help. I'm lost here...
Jason
Edit: No, I do not have a RAM Voltage adjustment. My RAM is also running at a much lower speed than what it is rated for. I have DDR400 RAM, but it is currently running at DDR266 speeds (plus overclock which makes it DDR272). I'm still well under specs.
PostPosted: Tue Aug 08, 2006 9:00 am
those are typical RAM errors. how many sticks and what manufacturer??
if you have more than 1, then take your bast stick {by manufacturer and type} and try to OC with just that mem stick.
you said your memory is undrclcocked? you might try running it over clocked just to see if it can handle it. might even fix your problem.
you might also want to run a benchmarking utility with it stock and OCed just to see how your overclock is taking. sometime an over clock will generate a bunch of errors and run slower than a stock system.
just my 2 cents...
AJ
PS just realized your mem speed. your running @ PC2100 speeds...you need to clock that memory up to where its supposed to be. i would be willing to bet that even with your system over clocked, it runs better at stock. benchmark to see.......
EVGA 790i tri SLI
water cooled fo sho
PostPosted: Tue Aug 08, 2006 9:59 am
Doesn't mean much. Some RAM requires above average voltage to run at certain speeds. The voltage your board is applying may only be enough for DDR266 and that's why its having trouble.
RIAA vs The People
PostPosted: Wed Aug 09, 2006 6:43 am
Hi all...
Thanks for all the great advice, but it seems to me that I am at a standstill at this point with overclocking this motherboard due to the fact that I don't have an adjustment for RAM voltage...
I'm running stable at 2.9GHz with a 544MHz Front Side Bus and my Oblivion performance is pretty decent. So, until such time as I decide to upgrade my motherboard, I am going to be sitting right here where I am at...
Thanks for all of the help. I'm not completely broken-hearted as I just purchased a Lenovo Laptop with the new Core 2 Duo processor in it, so all of my other applications except for Oblivion can be transferred over to that and free up my desktop for strictly gaming use...
Thanks,
Jason
