Newb
Newb
Postby Ge FOrce 543 » Mon May 01, 2006 3:17 pm
Hello I am a newb. I am building my first system and am wondering if I should over clock. I am not like stupid or anything and understand what it is but I need help. I am looking to get a 1.8 AMD Athlon 2000 processor, and a gygabyte hard drive. I am only starting out with 512 of ram but will upgrade in time. Well is there any advice.
Ge FOrce 543
BANNED!
Postby Tangible Demise » Tue May 02, 2006 6:28 pm
This forum doesn't get much attention, so I'll try to address it the best I can.
Overclocking or not depends on a couple of things... first of all, is your system capable of oc'ing in the first place. If yes, the second question is how hot does it run normally. If it runs hot under normal conditions, OC'ing isn't for you unless you do something to make sure the processor/mobo/memory all stay cool. Mainly the processor. And finally, if you can overclock and keep it cool, I wouldn't go over 10% MAX because it is an older processor. Just try 5% and if that runs fine, go to 10% but no more. :)
-Stu
My Rig:
AMD Athlon 64 4000+
Windows XP Pro x64 Edition
Windows XP MCE (Dual Boot)
250 GB x2 (500 GB Total) 7200 RPM RAID 0
nVidia GeForce 7800 GT
Asus A8N-SLi Mobo nForce 4
16x DVD Burner
Aspire 500w PSU
X-Blade Chassis
Tangible Demise
Postby Ge FOrce 543 » Thu May 04, 2006 1:56 pm
ok thankyou for the advice
Ge FOrce 543
BANNED!
