It is currently Thu Sep 20, 2018 7:08 pm
 Post subject: Overclocking a 4000+
PostPosted: Mon Apr 24, 2006 5:45 pm
I read the overclocking guides, and to be honest, I don't get it.
I have an Asus A8N-SLi board, which allows BIOS overclocking...
I want to overclock and I know how to change the settings, but I don't know what to change them to. Right now I believe the frequency is 200 MHz and the multiplier is 12. Not sure without checking on the voltage...
My cooler is decent, and when I had set the OC to 220 x 12, it ran around 125 to 130 degrees farenheit. I am guessing it can go more, but I need to know optimal settings...
Any solutions?
My Rig:
AMD Athlon 64 4000+
Windows XP Pro x64 Edition
Windows XP MCE (Dual Boot)
250 GB x2 (500 GB Total) 7200 RPM RAID 0
nVidia GeForce 7800 GT
Asus A8N-SLi Mobo nForce 4
16x DVD Burner
Aspire 500w PSU
X-Blade Chassis
PostPosted: Tue Apr 25, 2006 9:21 am
Ok... does this mean that nobody here has an overclocked A64 4000+?
Somebody here has to know what they are doing with that processor and overclocking!! :D
My Rig:
AMD Athlon 64 4000+
16x DVD Burner
Aspire 500w PSU
X-Blade Chassis
PostPosted: Wed Apr 26, 2006 8:04 am
You might want to look here:
http://mental18.phpbbweb.com/index.php? ... m=mental18
I have found it to be very helpful.
ASUS A8N32 Sli Deluxe
AMD Opteron 165
2 x 512 TEAM Group PC4800
ATI AIW X1800XL
2 x 74gig WD Raptors RAID 0
Pioneer 110D DVD+/-RW
PC Power & Cooling Silencer 750
PostPosted: Fri Apr 28, 2006 6:12 pm
I joined, but their login system doesn't work. I can't view the overclocking section without first logging in... :-/
My Rig:
AMD Athlon 64 4000+
16x DVD Burner
Aspire 500w PSU
X-Blade Chassis
PostPosted: Fri Apr 28, 2006 9:22 pm
I had that problem too. I eventually got logged in by registering under a different usename.
AMD Opteron 165
ATI AIW X1800XL
PostPosted: Fri Apr 28, 2006 9:32 pm
Here's a guide that explains everything pretty well. If you have specific questions just ask them.
PostPosted: Sat Apr 29, 2006 7:57 am
Can't speak for the A8N but the settings for my A8N32 SLI shouldn't be too far off. Here's a couple guides for that:
http://www.nforcershq.com/forum/a8n32-q ... 65243.html
http://www.nforcershq.com/forum/a8n32-s ... 64842.html
Hope it helps some.... :wink:
http://heatware.com/eval.php?id=30388
Asus Maximus IV Extreme Skt.1155
Intel i7-2700k @ 4.5Ghz
16Gb G.Skill DDR3-2133
2 x EVGA GTX460's
Corsair 1500W PSU
water on CPU
Asus Crosshair V Formula
FX-8120 @ 3.8Ghz
8Gb G.Skill DDR3-1866
ATI 3870x2
PostPosted: Sat Apr 29, 2006 6:54 pm
Thanks for the replies. A couple of those guides look pretty good. :)
My Rig:
AMD Athlon 64 4000+
16x DVD Burner
Aspire 500w PSU
X-Blade Chassis
