Is this how to run the Asus 845E at DDR333?
Postby James Cotter » Tue May 28, 2002 4:14 am
I would really appreciate it if somebody could look at this page and tell me whether this shows how to run the ASUS P4B533-E i845E at DDR333.
http://www.ocworkbench.com/2002/asus/p4 ... llery5.htm
Also does anybody know if this is overclocking the chipset or just enabling a feature that intel does not officially support.
Thanks for your help :D
:) James :)
James Cotter
Postby Tolemac » Tue May 28, 2002 10:58 am
I don't see where they are showing the P4B533-E as using DDR333(PC2700). They do show the P4S533 with the SiS 645DX chipset as using the DDR333.
Tolemac
Postby James Cotter » Tue May 28, 2002 11:09 am
Hi Toley :D
Thanks for responding
They say on the next page that they ran it with DDR333
http://www.ocworkbench.com/2002/asus/p4 ... 533ep2.htm
"Intel 845E series
ASUS P4B533-E, MSI 845E Max2, DFI NB73-EA, Gigabyte 8IEXP
Intel Pentium 4 2.4G 533Mhz
512MB Winbond DDR333 DDR
ThermalTake heatsink/fan
Maxtor 40G ATA133 7200RPM
MSI Geforce3 Ti200 /Detonator 21.83
Windows 2000 + SP2
Intel Application Accelerator "
I was wondering if the picks of the bios show how they did this. Or does this mean that allthough they used DDR333 they only ran it at 266.
Thanks
James :mrgreen:
Also what is the difference between async and sync
James Cotter
Postby Tolemac » Tue May 28, 2002 11:18 am
Go to the page after that one that shows the SANDRA benchmarks and you will see that they tested the P4B with DDR266 and the P4S with DDR333. I believe that the page that you just linked me to is a mis-print on their part.
Tolemac
Postby James Cotter » Tue May 28, 2002 11:23 am
Thanks Toley,
I thought i had finally found a review of the Asus 845E running at DDR333, damn :evil: :evil: :evil: . Guess it is back to the drawing board and the decision whether to get the 845E or 845G then. Thought i had finally sussed it and it was a simple case of changing a bios setting and the 845E ran fine. Back to searching the web then :evil: . Cheers for sorting that one out for me.
James :D
James Cotter
Users browsing this forum: Majestic-12 [Bot] and 2 guests
