Overclocking XP's...the THG way
Postby The Disturbance » Mon May 27, 2002 5:17 pm
are you supposed to apply the liquid lacquer or all of the L1 things or just the left ones...and to you tape it over then put the heatsink/fan on the processor with the tape on? Also what is the auto voltage, ratio, and vdimm ratio/voltage for an Athlon XP of 2000+? Thanks!!!
The Disturbance
Postby andrey » Mon May 27, 2002 5:51 pm
ok, I assume you already filled the valley..
put that other stuff then to connect the L1 series vertically, without it touching each other horizontally. all 5 of them.
then yep tape it down so it won't move around, and then apply the HSF on top of it with a thermal compound. just leave it all on default voltages if you don't plan on overclocking (but then why would you unlock? hehe) don't worry about the DIMM voltages, thats for the RAM. increase the CPU voltages anywhere from .5 to 1 volts, or higher if you are watching your temps.
________
california dispensaries
andrey
Postby Aibohphobia » Tue May 28, 2002 8:11 am
Make sure you apply a very thin layer if you are to tape over it, otherwise it will smudge and connect all the L1's horizontally.
Goddam mad dog!
Aibohphobia
