What Can i do with it?
Postby twigg » Mon May 27, 2002 11:09 am
Hi!
I have a pcchips M560 runnining a pentium MMX
What can I do with it how fast will it go and how do I do it!!!!
HELP! please!!!
Twigg :)
twigg
Postby datektrader21 » Mon May 27, 2002 11:56 am
I hear PC chips boards make good Frisbees j/k. Other than that try playing with the settings. fsb, voltage, and multipliers if you can. see how high you can get while still keeping the system stable. most of these settings can be changed in the bios.
datektrader21
Postby Toby B. » Mon May 27, 2002 9:55 pm
The M560 V3.1 & V4.1.
321pin ZIF socket 7 which supports these processors:
INTEL Pentium 75~233MHz P54C, P55C MMX
CYRIX/IBM 6x86MX(M2), IDT C6,and AMD K5/K6 CPUs
- Supports 50/60/66/75/83.3 MHz external clock speeds
I am unsure of the outcome. Hope this helps
Toby
Toby B.
Postby Toby B. » Wed Jun 12, 2002 8:35 am
Toby B.
