It is currently Sat Sep 19, 2020 1:44 pm
Post new topic Reply to topic  [ 238 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 24  Next
PostPosted: Fri Apr 08, 2005 1:29 pm
ok... a little better. I used the linked version of superPi this time and...
Memory:
Frequency: 167Mhz
FSB:Ram: 6:5
Cas# Latency: 2.5Clocks
Ras# to Cas# Delay: 3 Clocks
Ras# Precharge: 3 Clocks
Cycly Time(Tras): 7 Clocks
Should I change the memory timings?
PostPosted: Fri Apr 08, 2005 3:03 pm
Oylpann, open up your notepad and change the font, that might do the trick.
Rob, try setting the TRAS to 9, 10, or 11 with the Nforce2 chipset for a small performance boost. Also see if you can get the CAS to 2 and the other timings to 2.
PostPosted: Fri Apr 08, 2005 3:13 pm
Hmm... sorry for the post spam... I was looking at my screenshot and noticed something extremely odd... it's not the voltage of the CPU, which is read wrong. Look at how much memory it shows I have. That's a tad bit off.
I guess the program can't read the info from the AV8 correctly.
PostPosted: Fri Apr 08, 2005 4:50 pm
Thanks Peanya, will do! When I get home that is :)
Asus F2A85-V Pro
AMD A10-5800K APU @ 4.5GHz
8GB G. Skill 1866
550w PSU
Hyper 212 Evo
PostPosted: Sat Apr 09, 2005 12:42 pm
Seems about right for my Socket 754 build. Im not using the greatest ram in the world either. 1x512mb Geil Value Series PC3200, 1x256mb Geil Ultra Platinum PC3500.
Main rig: 1/2" ID Water Cooled Lian-Li V2000B, Abit IP35 Pro, Intel C2D [email protected] -3.4ghz 1.3375v, Mushkin 2gb DDR2-800 996576, one terabyte storage, evga 7900GS KO w/ Zalman VF700-AlCu cooler, Swiftech Apogee GT water block, Ultra X2 550w PSU
Laptop: Asus Z70VA, Pentium M 725 [email protected] -2.13ghz (pinmod), ATI X700 Pro, 1680x1050 native res., bluetooth, the works...
Last edited by YouGiveMeRash!!! on Sun Apr 10, 2005 10:18 am, edited 1 time in total.
PostPosted: Sun Apr 10, 2005 9:44 am
wow rash, you had your A64 at 2.5Ghz. i have the same stepping at yours but i still can't get past 215FSB. its probably my psu, anyways will still keep on tweaking before i post here again
Join the Motherboards.org Folding Team 33258
PostPosted: Sun Apr 10, 2005 10:17 am
Well actually Ryn, I can get it up to about 2.65 rock stable at 1.65v but since I dont have agp/pci locks, I get video corruption in games.
It works fine at the desktop and while folding, but when i play games the video gets all screwy.
If only I had a socket 754 nforce 3 board, I would be able to take it to 2.7ghz most likely. :twisted:
I run my A64 at 2.5ghz all the time though. :wink:
PostPosted: Sun Apr 10, 2005 10:41 am
well i still have my MSI K8N Neo Platinum lying around here in my room. you can have it if you want but you must get it here in my place hehe :twisted:
PostPosted: Sun Apr 10, 2005 6:19 pm
Why did you get rid of the MSI? :?
PostPosted: Sun Apr 10, 2005 9:15 pm
coz it doesn't have locks on the SATA ports that's hindering me from oc'in
