It is currently Wed Aug 05, 2020 2:02 am
Post new topic Reply to topic  [ 238 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24  Next
PostPosted: Sat Nov 12, 2005 8:27 am
How do you take a pic of your screen?
PostPosted: Sat Nov 12, 2005 8:35 am
Run the tests and then push the Print Screen (sometimes labeled PrtSc) button on your keyboard (usually on the top row near the numeric keypad). Now you will have the bitmap in your clipboard. Then go into your favorite graphics program (PaintShop, Paint, or whatever), and edit-paste the clipboard into a new image. You will now have the screen shot that you can save as an image file. In this case, using .gif format is probably reasonable for smallest file size. For this type of image you don't need many colors, so using .gif with 2, 4 or 8 colors will significantly reduce the file size over .gif with 256 colors for example. You could use .jpg if you select a high compression. Just make sure that you end up with the smallest file size possible so you don't bog down the page when people try to view it.
PostPosted: Sun Nov 13, 2005 5:00 pm
what score does a p4 2.8 get with 512 ram (ddr333 i fink)
to build or not to build,
that is the question?
PostPosted: Thu Dec 01, 2005 12:41 pm
what score does a stock fx 59 get?
PostPosted: Thu Dec 01, 2005 1:26 pm
i didn't think they were out yet do you mean 57?
Join team 33258 today!!
PostPosted: Thu Dec 01, 2005 1:49 pm
actually did mean fx59 but didnt realise it aint out lol. what score does a stock fx 57 get?
PostPosted: Thu Dec 01, 2005 1:53 pm
it might not be even called the fx59 i saw one article that say it will and another one says fx60
don't think anyone has a fx57 on here since there so much money
its probally very fast i am interested in seeing what the dual core cpus can do
PostPosted: Thu Dec 01, 2005 1:55 pm
im lookin to challenge peanya with my hopeful opteron at 3ghz :twisted:
PostPosted: Mon Dec 05, 2005 10:51 am
8O uhhooohh... but...
You ahe to get thru me first PDT_Armataz_01_25
:lol: :lol: :lol:
Image Image
PostPosted: Mon Dec 05, 2005 12:00 pm
dont worry im coming :wink:
you 2 got a lil lucky, got my chip the other day but it a cab2e :(. it a oem so im waitin for hsf and arctic silver to arrive. i booted it up with a stock 3200 cooler, and cud get i to 2.8ghz stable, but anaything higher was a no go :(. ill tweak a lil more wen it all here and set up, hopefully i can hit 2.9ghz. i reckon i can get through evil, but sadly not peanya. if i had a better board and water, i reckon this chip cud do 3.1ghz
