SuperPi Challenge
Post Reply
Peanya
Post by Peanya »
Tulatin not updating this any more?
Tulatin
Contact:
Post by Tulatin »
tulatin will, but like he said the file is lost. He's also been quite busy. If you'll be patient, it'll be done. Thank You. :D
headofmax
Contact:
Post by headofmax »
I got new ram
new time 39.511 with mushkin pc3200ddr
also OC'd to 3.44ghz
Will post pic later
DFI Lanparty Venus
Opteron 165 @ 2.8
Thermaltake Big Typhoon
2X1024 G.Skill
ATi 4770
GameXtreme 700W
LG 37" 1080P LCD
Hannspree HW191D widescreen
Tulatin
Contact:
Post by Tulatin »
Rebuilding now.
Tulatin
Contact:
Post by Tulatin »
Rebuilt. I'll be in second in 15 minutes.
Barely, Just barely. Shoot folding, gain a third of a second.
Me is guilty of hubris :(
Ryn
Contact:
Post by Ryn »
here is an addition for my oc'ed Mobile AthlonXP 2400+
specs:
DFI Nforce2 Ultra Infinity
Twinmos DDR400 2x256MB
Task 350W PSU
ThEvil0nE
Contact:
Post by ThEvil0nE »
My 3800+ Rev. E only on the 30s :? This is as stable as it went...
Timings: http://i3.photobucket.com/albums/y60/Th ... 280x10.jpg
Her's the default settings: http://i3.photobucket.com/albums/y60/Th ... efault.jpg
Image Image
Tulatin
Contact:
Post by Tulatin »
EvilOnE - get that RAS to CAS latency down, and run in realtime, you should be able to JUST make it under 30s.
lilpaki
Post by lilpaki »
2 questions... wat you mean run in realtime?
and for thouse of you out there with a asus a8n sli, how do you set the cpu/ram ratios? i got the 1011 bios.
thanks for ya time
to build or not to build,
that is the question?
Tulatin
Contact:
Post by Tulatin »
Run in realtime = open up the task manager, go under proccesses, right click superpi.exe, and select realtime from the priority menu.
As to setting CPU/RAM ratios on the A8N-SLI, go under CPU Configuration in the advanced menu, and your ratios will be under DRAM Configuration, with the heading Memclock Index Value (as seen here). Now, bear in mind that i NEVER could get DDR333 to work, so if you want to use that ratio, you're going to have to set it to DDR266, then up it with A64 Tweaker in windows. As to respective ratios, DDR333 is 5:4, DDR266 is 3:2 and DDR200 is 2:1
Finally, if you're solder savvy (or confident, or can have it done by another) there's a few voltmods you can do to the board to improve performance. THe general consensus on these motherboards is that the HTT WILL NOT break the 300MHz mark - a voltmod near the chipset fixes that, and likewise there's a RAM voltmod to boost and stabilize ram voltages. I did the chipset one, but i think i killed the mobo by making the new sink (zalmy passive) rock and chip the chipset. IF you want the guides for the V-mods, i can PM them to you
Post Reply
