It is currently Wed Jan 16, 2019 12:45 pm
PostPosted: Sun Dec 12, 2004 1:05 pm
You can do up to 2.3GHz with any heatsink on your CPU. It runs very cool. Going past that you'll want to get better. That heatsink you listed is very noisy at higher RPM's, so be warned about it sounding like a hair dryer.
PostPosted: Sun Dec 12, 2004 3:27 pm
I have a Thermaltake Venus 7+
It isnt that loud. I have never heard it reach its max 6000rpm because my CPU stays cool. The highest I have seen it go is 3500rpm which is around 30db.
At load, my temps never go above 40 degrees celsius.
If I OC to 2.35ghz, temps never go above 48 at load.
Its a pretty good heatsink.
